Hello, from a long time lurker first time poster 👋
I've spent a week now trying to figure out how to best clean up and convert the NTSC DVD of Curb Your Enthusiasm, which exhibits a combination of various distortions.
Original MPEG source - remuxed directly from the DVD into MKV:
[Attachment 53512 - Click to enlarge]
There's a few issues visible on the image when you zoom in (or watch the video):
1. door behind him has the top/left edge blurry - wavy
2. the mirror frame on the wall has jagged edges
3. he's got jagged shoulders (as does any movement)
4. the white door frame on the right has jagged top edge
5. the vase on the right has jagged edges
If I run it through QTGMC on placebo setting, it'll nicely cleanup 3, 4, 5. But no matter what I do, the 1 and 2 issues still persist. The door top edge is wavy/blurry and the mirror is jagged and shimmering. Even if I Bob it and compare the frames, it seems these issues are already present in the original master.
I've tried various deinterlacing filters, some antialiasing filters, also stabilisation and any imaginable combo of these, but absolutely no improvement whatsoever, the door is still waving blurry and the mirror is still shimmering
Any ideas please? Thanks
The MPG2 video is already screwed up. A higher resolution video was deinterlaced and downscaled badly. This looks a little better:
I'm not sure the second QTGMC helps much. You might leave it out.Code:Mpeg2Source("cye-home_track1_eng.d2v", CPU2="ooooxx", Info=3) # clean up vertical edges TurnRight() nnedi3(dh=true) Spline36Resize(width,960) QTGMC(InputType=2) TurnLeft() # clean up horizontal edges QTGMC(InputType=2) Spline36Resize(960,720)
NTSC Source
By johnny27depp in forum Newbie / General discussionsReplies: 24Last Post: 19th May 2019, 11:45 -
NTSC blended from a PAL source, can't restore it properly
By bruno321 in forum RestorationReplies: 5Last Post: 6th Oct 2018, 11:42 -
Need help with AVISynth script - source badly converted from NTSC?
By duffbeer in forum DVD RippingReplies: 3Last Post: 29th Dec 2017, 03:56 -
DVD: have both NTSC & PAL - best source and settings?
By U2Joshua in forum Video ConversionReplies: 4Last Post: 10th Jan 2017, 00:28 -
Laserdisc BEST source (PAL vs NTSC)
By darkbluesky in forum Capturing and VCRReplies: 35Last Post: 8th Jan 2017, 22:28
cause I'm running out of ideas
