This appears to be a fairly common problem it seems after I did a little research but I still can’t find a solution. I basically slide the eject release and that door opens then nothing happens. The entire tray with the minidv never slides up. I don’t currently have a tape in the camcorder. I’ve tried unplugging and letting it sit, tried battery only, plugged in AC only every once in a while it will randomly pop out but just once. I can’t seem to figure out what is causing it what kind of rhyme or reason but id love to get it operational. Any suggestions?
Hello,
I had a similar problem with my mum´s camera, not the same model (hers is ZR90 mini) but maybe this helps you.
The camera would open but the cassette sometimes just would not come out so i used a screwdriver to "fix it".
I opened the cassete housing and on the right side it says "press". There is a little spring hidden. I then used a small screwdriver to push the spring down just a tiny bit and it somehow worked. I don´t know exactly how and why it worked but the cassete came out. This worked a couple of times actually.
Maybe this will work for you too (but be careful not to damage the camera)!
BTW: we bought a "new one" off of ebay afterwards because that problem was really annoying
TRV120 D8 cam won't play most old 8mm tapes, any recommended 8mm camcorders
By analog2digital in forum Capturing and VCRReplies: 1Last Post: 22nd Feb 2020, 11:44 -
Sony Camcorder TRV815 Hi8 old tapes won't playback in camcorder
By Dforsythe in forum Newbie / General discussionsReplies: 11Last Post: 9th Dec 2019, 16:21 -
Canon Legria HF G40 with Canon SM-V1 Surround Microphone Problem
By dpaterson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 8th May 2018, 12:03 -
Trying to see my tapes from the 90s! Are the tapes broken? Or my camcorder?
By melissa in forum Newbie / General discussionsReplies: 6Last Post: 3rd Sep 2017, 20:49 -
Vintage Panasonic M5 camcorder wont eject tape
By coffee_king in forum Capturing and VCRReplies: 1Last Post: 23rd Nov 2015, 21:35
