Hi
I have 2 video files.
1st
container: mkv
codec: x264
fps: 25
audio: aac
2nd
container: avi
codec: xvid
fps: 23.976
audio: ac-3
What I want to do is mux the audio from the 2nd video file into the 1st.
Is this possible?
What tool do I need to extract the audio from the 2nd video?
Then I can use megui to mux the audio into the first video file but I sense problems will arise because of the different fps.
Is this fixable?
Can one change fps of an audio? lol
Changing the fps of the first video file to match 23.976, will it be okay?
You have to convert the 2nd audio from 23.976 fps speed to 25 fps speed (with or without pitch correction) and then mux 1st video with converted audio to a new output.
Both can be done with my clever FFMpeg-GUI -
It's rare that NTSC and PAL versions of a movie are the same cut. Don't be surprised when you find you can't just adjust the length of the audio to sync them.
Yeah, I also had to cut the first 8 seconds of the audio using mp3directcut and I've synced it nearly perfectly well.
how can I mux 25 fps audio into 23.438 fps (1024 spf) ?
By precipizio in forum AudioReplies: 12Last Post: 16th Apr 2020, 15:06 -
Muxing two audio tracks from different sources with different fps
By xaz in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2019, 09:37 -
joining elementary stream files (.avc) and muxing ac3 audio
By vorpaljim in forum Video ConversionReplies: 0Last Post: 11th Feb 2018, 18:23 -
Tsmuxer: H.264 muxing fps is not set
By Patapin in forum Video ConversionReplies: 4Last Post: 17th Jul 2017, 14:12 -
Convert 51.43 fps video in 59.94 fps container to straight 50 fps video
By mr_lou in forum Video ConversionReplies: 5Last Post: 8th May 2016, 12:47
