Is it right that that the rendering engine will make a difference?
Let's assume a video editing program where i have introduced a title and a few transitions on the clip cuts on an mp4 video.
I run this through the smart re-encoding feature of the program which only re-encodes the manipulated portions of the video v/s rendering it with full re-encoding (not using smart render feature) - How much decrease in quality would there be and is this quantifiable (apart from trusting the naked eye)?
Would just like to understand te concept and what i am losing out on by not having a smart render feature in my editor!
Thanks experts at Videohelp
	Anytime you re-encode with a lossy codec, it is going to lose some quality. Even at the same bitrate. I have no way of quantifying it as it just depends on how good the codec is and what settings you used and how complex the content is (movement).
	Ooops i did not make myself clear
 I meant if i used the same codec (eg mp4 x264) and the output after a few edits was also the same (mp4 x264) then what??
	Same answer.
 Smart rendering means copying that clip segment (if possible) vs re-encoding. So lossless vs lossy. Sometimes lossy isn't noticeably worse, sometimes it is. The underlying pixels ARE always degraded, though.
 You could run a few tests and compare at certain bitrates using psnr or something as a quantitative objective measure, but it's always ultimately a qualitative judgement call, which is mainly subjective.
	In theory the "smart rendered" version may be of somewhat higher quality, due to not having to re-encode the whole file.
 Just curious, are you working with Pegasys' software?
  Rendered video brightness issue (Vegas)By Welsh Jester in forum EditingReplies: 2Last Post: 6th Mar 2019, 07:10
  Rendered video does not display/behave as in previewBy muel2002 in forum Video ConversionReplies: 3Last Post: 29th Jul 2017, 15:26
  A 23.98FPS video rendered in 29.97 retains the same runtime, why?By skribby in forum Newbie / General discussionsReplies: 7Last Post: 29th Sep 2016, 11:37
  Video flickers when rendered - yet again!By serazoo in forum EditingReplies: 5Last Post: 22nd Nov 2015, 10:57
  H265 - Any tool to make a "smart rendered" cut?By Seeker320 in forum EditingReplies: 2Last Post: 4th Oct 2015, 21:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
