I have used XML2VCD to try to learn about this Advanced Menu thingies... but what what do I do with the XML file I got? I thought it would give me an VCDimage to burn...
please help!
run vcdxbuild whateverufilenameis.xml
r@yjr13 ¦-< what you lookin at¿ :o
¡Now selling audioly and visually challenged coasters, frisbees, and vanity mirrors! -
It comes wit Vcdimager
Or if it's in soem command line somewhere... well then..WHERE?? I'm not a command live lover... so I would'nt know when or how to use it. I know how to ping though
Thanx/
Lars -
Did'nt come with the ZIP file I downloaded from here... is it a exe file or a command?
Thanx/
Lars -
if u downloaded the vcdimager0.7.x zip,tar, whatever file....when u unzip it there are about 5 command line executable which means u have to start MS-Dos Command prompt under START>PROGRAMS> then access the directory with vcdimager.exe in it
enter
c:\...\vcdimager0.7.7\Vcdxbuild.exe whatever.xml
CLI to XML
By eon_designs in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 11:50 -
filmindex.xml....WTF?
By ni9ht_5ta1k3r in forum Blu-ray RippingReplies: 8Last Post: 6th Jun 2009, 07:01 -
Transport stream for XML?
By TrupsT in forum Video Streaming DownloadingReplies: 1Last Post: 30th Jan 2009, 12:25 -
DriveImage XML
By blockie@sbcglobal.ne in forum ComputerReplies: 2Last Post: 25th Jul 2008, 17:25 -
ProjectPrefs2.xml keeps old clips
By geohei in forum Authoring (DVD)Replies: 4Last Post: 11th Jul 2007, 08:34
