Hi, noob here, looking for help.
I just received an mp4 video (made with a mobile phone, 1 minute 12 seconds length) of my husband's great-aunt who passed away yesterday.
My in-laws would love to show the video at her memorial (coming Saturday) but unfortunately the person who recorded it started out holding the phone in a horizontal position, rotated it to vertical, and rotated it back to horizontal.
They asked me to correct it as I'm the family-nerd.
Is there a way to correct this so people won't have to tilt their heads one way and the other when viewing it?
I already thought of cutting up the video in three parts, and rotating them so all parts are in the same direction (I still have to figure out how to do that).
I know this will cause black bands on either top/bottom or left/right but anything is better than nothing.
Do you know a better way?
In case it's important I've added the MediaInfo information for the clip:
General
Complete name : D:\VID-20200524-WA0014.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 18.0 MiB
Duration : 1 min 11 s
Overall bit rate : 2 107 kb/s
Encoded date : UTC 2019-05-17 09:06:56
Tagged date : UTC 2019-05-17 09:48:37
Writing application : Google
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Codec ID : avc1
Bit rate : 1 978 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.786 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.032
Stream size : 16.9 MiB (94%)
Title : ISO Media file produced by Google Inc. Created on: 05/17/2019.
Writing library : x264 core 155 r2901 7d0ff22
Encoded date : UTC 2019-05-17 09:48:37
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 1.09 MiB (6%)
Language : English
You could try using Avidemux available from this site to cut the sections you require then use a free program called Video-Flip-and-Rotate https://www.dvdvideosoft.com/products/dvd/Free-Video-Flip-and-Rotate.htm to alter the vertical to horizontal & then use Avidemux to join the parts together.Should you encounter a problem you could try using Handbrake available from this site to re-encode the merged parts.
Problems correcting perspective in video using FFmpeg
By nickrob in forum Video ConversionReplies: 0Last Post: 3rd May 2020, 07:40 -
Question about TBC in correcting issues with captured SECAM video
By autephex in forum Capturing and VCRReplies: 43Last Post: 13th Dec 2018, 18:08 -
Video call partially rotated
By Alonshow in forum Newbie / General discussionsReplies: 26Last Post: 18th Jun 2016, 12:08 -
Correcting colour cast on video.
By efiste2 in forum Video ConversionReplies: 3Last Post: 11th Mar 2016, 05:23 -
Correcting a video taken from bad TV retransmission
By XenonS in forum RestorationReplies: 8Last Post: 25th Oct 2015, 16:11
