my friend picked up the ati aiw capture card. i have the dazzle dvc ii
so i don't know too much about the ati card. he captures a svcd at
compliant settings (ntsc, mpeg-2, 2.5 Mbps). he burns using nero.
he has to turn the compliancy check off but after burning, it plays well
on his apex dvd.
my question: what editing software do you guys use after you capture
from the ati aiw? tmpgenc? ulead video studio? and what editing
software prevents complete re-conversion of the file. with the dazzle,
if you capture at a certain template in moviestar (the dazzle cap and edit
application), then editing takes seconds (i.e. clipping commercials).
is there an editing software that can do the same with captures from the
ati aiw or does re-encoding have to be done? which is the best software?
thanks.
su
Results 1 to 1 of 1
Video Editing Software Question
By Souwalker in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2009, 21:08 -
Vista 64 and most Video editing software QUESTION
By zapper130 in forum Capturing and VCRReplies: 7Last Post: 20th Apr 2009, 19:04 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 14:52 -
ATI Radeon HD 2600 XT 512 Mo PCI-Express for HDTV, ENCODING,EDITING
By leguerisseur in forum DVB / IPTVReplies: 0Last Post: 21st Sep 2007, 07:30 -
H264 x264 ATI Radeon Vid Card Question
By mforcex in forum Newbie / General discussionsReplies: 6Last Post: 25th Jun 2007, 09:59
