Results 1 to 9 of 9
  1. I am trying to configure my Task Manager to Auto Shutdown my pc at a certain time.I followed the instructions from the videos available on the net. I set the path to windows/system32/shutdown.exe. I put /s/f in the options as told as well. The Task Library gave a 0x1 error. I then used another video to add the script before the "/" to options. This said "task completed successfully". However neither attempt actually shut down my pc. I am the admin. Any suggestions
  2. Member DB83's Avatar
    Jul 2007
    Surely it is shutdown -s not shutdown /s
    Mar 2008
    "/" works fine.
    I entered this in the CMD window and the system shutdown in about 10 seconds
    shutdown /s /f /t 10
    Perhaps there will further clues on this webpage:
    https://www.thewindowsclub.com/schedule-shutdown-restarts-windows-7-task-schedular/
  4. Member DB83's Avatar
    Jul 2007
    Yeah. But there seems to be subtle difference between the CMD window and the Task Manager.
    I have not tried either. Just relaying what I read from a quick Google.
    https://helpdeskgeek.com/windows-10/how-to-automatically-shut-down-a-windows-computer/
    Mar 2008
    Sure, wouldn't hurt to try it
  6. Yes those are the instructions I followed. I did it again and added a "0". At the time I specified "1:35 PM" (a couple minutes after configuring), the screen blinked. However, it did not shut down, and it returned a 0x1 error.
  7. Member DB83's Avatar
    Jul 2007
    Did you try it with the '-s' ?
    I might test it myself later but I am not inclined to attempt to shutdown right now
  8. Originally Posted by DB83 View Post
    Genius!! Thank You
  9. I have this scheduled: c:\windows\system32\shutdown.exe /s It's set to run as administrator, whether the user is logged on or not.
    I couldn't make it go as a generic user, had to set it as an administrator, then it worked. It's been working every night for years.
