Hi everyone! I hope you are all doing well!
i have been learning languages and i thought it would be a good idea to use double subtitles on the same video.
So essentially i have an english subtitle at the bottom, and the Russian subtitle, the language I'm learning on top.
My issue is that these two subtitles are not synced properly. One is too fast and the other too slow.
I've tried using Alt+E to sync it better, but the issue is that it is changing the sync for both subtitles.
Whereas what i need is to apply different syncs to each subtitle.
Is there any way, I can change the sync for one and maybe save it? and then change the sync other?
Instead of Potplayer applying the same sync to both.
Thanks in advance for your help!
If the subs are text (e.g. .srt, .ass, .ssa, etc) you can adjust the timing with Subtitle Edit. If they're sub/idx, VOBSub.
You'll have to adjust the timing on both.
DAUM PotPlayer skin customizations
By c627627 in forum Software PlayingReplies: 30Last Post: 31st Oct 2024, 13:05 -
Daum PotPlayer - Spyware? - Please help
By artichoke in forum Newbie / General discussionsReplies: 23Last Post: 14th Sep 2020, 00:39 -
Confused: potplayer.daum.net OR daumpotplayer.com ?
By potuser in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2020, 15:41 -
Daum PotPlayer solid color instead of subtitles
By XpyM in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jun 2019, 04:31 -
Daum PotPlayer + DVBS2 Card issue
By szczygiel in forum Software PlayingReplies: 1Last Post: 19th Feb 2019, 13:31
