Hi Gang,
I am working with frames that are 1440 x 1152 (5:4 Double PAL). I would like to render them in within the structure of a 1920 x 1080 format, but can't seem to get the right combination of Project Settings and Render Settings so as not to alter the ratio of the picture (it looks slightly squished after rendering).
Can someone please offer some advice on how to get that accomplished? Thanks so much![]()
To set desired aspect ratio:
You can do it this way,
1. make your project 1920x1080
2.Drop you video on timeline.
3.make 1440x1080 solid color and put it underneath your video. If 4:3 (1440/1080) is what you want.
You delete it when done, it is just to see true aspect ratio on screen.
4.In pan/crop Override locked aspect ratio.Then use pan/crop borders to drag it to match your SD footage to that rectangle.
Because for example if just dropping 720x480 DV into fullHD project Vegas might use 704 to calculate new width, which might be not desired. Something similar in PAL. Or just use that above workflow to fix something. -
Instead of pan/crop try Track Motion, unlock aspect ratio, you can stretch height or width, hopefully that one works. Not sure about that pan/crop, tried it now and I could not do it.
These sort of things is better to do outside of Vegas using Vapoursynth or Avisynth, but that is difficult to set it up, only if you have those working already.
Frame by frame editing - Premiere Pro, Sony Vegas, or ???
By Zoltan Losonc in forum EditingReplies: 60Last Post: 19th Aug 2016, 16:30 -
Vegas: rendering in wrong Frame size (Batch render)
By AdrianoX in forum EditingReplies: 0Last Post: 29th Jun 2016, 00:13 -
aspect ratio conversion.... for real?
By derwildemann in forum Newbie / General discussionsReplies: 11Last Post: 9th Mar 2016, 12:49 -
Diabolical PAL - NTSC framesize aspect ratio VHS conversion problem - Help!
By tj7 in forum RestorationReplies: 18Last Post: 8th Sep 2015, 22:45 -
Video Conversion to 16:9 aspect ratio
By videofeed in forum Video ConversionReplies: 8Last Post: 2nd Jul 2015, 10:02
