Hello guys, I wonder if there is a way to removed banding from an animation video in handbrake. I read that I can add some noise/grain to the video but I can't found that options in handbrake.
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 684 MiB
Duration : 23 min 13 s
Overall bit rate : 4 128 kb/s
Writing application : Lavf58.29.100
Video
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames
Codec ID : avc1
Duration : 23 min 9 s
Bit rate : 4 000 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 23.976 (24000/1001) FPS
Minimum frame rate : 23.974 FPS
Maximum frame rate : 23.981 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Stream size : 662 MiB (97%)
Writing library : x264 core 142
Encoding settings : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=10 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=96 / keyint_min=48 / scenecut=40 / intra_refresh=0 / rc_lookahead=48 / rc=2pass / mbtree=1 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=6000 / vbv_bufsize=9000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:0.60
				Results 1 to 1 of 1
  Does CGI animation require more or less bitrate than Hand Drawn animation?By killerteengohan in forum Newbie / General discussionsReplies: 13Last Post: 29th Mar 2019, 11:50
  Critique my 2d animation ( explainer video)By khazha in forum Newbie / General discussionsReplies: 3Last Post: 3rd Sep 2017, 03:43
  Help : Encoding Video from Interlanced to Progressive using Handbreak 10.By lordsparkles in forum Newbie / General discussionsReplies: 0Last Post: 4th Oct 2016, 07:05
  Improve the quality of video animationBy SB4 in forum RestorationReplies: 50Last Post: 15th May 2016, 15:10
  [No video track found] ffms2 and Cineform (banding, high bit depth)By 4K_ in forum Video ConversionReplies: 3Last Post: 15th Oct 2015, 19:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
