Hello,
I used this dvd recorded for most things I record off my dvr. I have a coaxial going directly into the recorder from the cable box. My question is, how much better would the recordings be if I were to run the 5 rca cables through the recorder instead of the coaxial? Would it be alot clearer or not enough to worry about?
Additionally, sometimes I use my pc to record programs. They are usually mkv files that are 1280x720. I use convertx2dvd and a standard 2 hour dvd-r. Should these have superior picture quality than the dvds I record from using the panasonic standalone recorder? Because I dont see a big difference.
First the RF coax is the worst quality connection, basically anything else should be better. Second I have no idea what you mean by "5 RCA cables" as that would be component and the ES-30v has no component input, only output. Component would be the best connection to run from the ES-30v to your TV(if your TV has component inputs) but this will make no difference on recoding, just playback.
As I said RF coax is the worst recording input, composite should be better and S-video a bit better than that, again if you have a S-video output on your cable box, which no modern ones do, only an old STB might have it.
I don't really use a PC to record so I don't know anything about your last question.
Panasonic DMR es-18
By Joe S in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2017, 16:34 -
Panasonic DMR-EZ48V
By don356 in forum Newbie / General discussionsReplies: 4Last Post: 4th Dec 2016, 21:09 -
Panasonic dmr-bwt850eb ?'s
By Seven pounds in forum DVD & Blu-ray RecordersReplies: 0Last Post: 17th Jul 2016, 12:16 -
Panasonic DMR-EH 60 Problems.
By andya1412 in forum Newbie / General discussionsReplies: 2Last Post: 31st Mar 2016, 06:51 -
panasonic DMR-E75V
By arkiboys in forum DVD & Blu-ray PlayersReplies: 20Last Post: 25th Sep 2015, 10:43
