After capturing a TV-programm with my ATI RADEON AIW in mpeg2 format I have no sound when playing the file with Windows Media Player.
While playing the file with th MMC Fileplayer I do have sound.
Sound is captured.
Do more people have this problem? I don't want others to install the MMC Fileplayer just to view my mpeg's.
Is there a solution?
I have the same card but I don't have that problem. How did you encode the MPEGs? Did you capture straight to MPEG using MMC? What you may need to do is setup a custom capture format to make sure the codec and setup for the capture is correct.
Regards,
Savant -
Yes, I captured with the standard mpeg2 settings in the VCR app.
Besides that I also have a problem using slider bar (forward and backward) when playing the file with Fileplayer. By using this feature the sound gets out of sync. That was the main reasen for trying with the WMP, but then I discovered there as no sound at all.
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 20:56 -
Music sound playback is greater than word sound playback
By shknoll in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 13:09 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 14:52 -
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 01:03 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 15:25
