Hi, I have both vcd of movie with original colors/contrast/brightness etc, which colors have been distorted in dvd of the same since dvd has superior details than vcd. I want to color correct the dvd version, to original colors in vcds it possible to adjust and correct color of dvdrip to original colors of vcd? what software to use for color correction without loss of quality?
Also how to extract mpeg 1 streams from vcd. Dat files, and then mux them into mkv
Also is it possible to sync dvd audio with vcd video, how to do that?
You can use my clever FFmpeg-GUI to extract or reencode the video stream of your vcd.dat.
Also can you extract your DVD audio with Pgcdemux and then use clever FFmpeg-GUI to mux them with the new created vcd video to mp4 or mkv.
Color correction
By Shingen36 in forum EditingReplies: 0Last Post: 20th May 2020, 05:16 -
To use color correction or not?
By That Tommy in forum EditingReplies: 3Last Post: 30th Aug 2018, 16:35 -
Super 8 on VHS (Color Correction)
By TONYFRANCE in forum RestorationReplies: 5Last Post: 16th Apr 2018, 08:14 -
Help with color correction
By navi82 in forum RestorationReplies: 6Last Post: 3rd Apr 2017, 05:42 -
What do you think of the color correction and grading?
By newpball in forum EditingReplies: 4Last Post: 27th Jul 2015, 15:04
