My .avs file:
My question is, if there is no leftover interlacing (i.e in the debug output it says "CLEAN FRAME" for all the frames), is TDeint() still called? Does the encoding go faster if all the frames are clean?Code:D = TDeint(mode=2, mtnmode=3, blim=100) TFM(slow=1, clip2=D, output="output.txt", debug=true) TDecimate(mode=1)
No. But you might also try:
TFM(slow=1,Display=true)
TDecimate(mode=1)
Play it and if deinterlaced then it says "DEINTERLACED". But I don't know why you'd use TDeint as the post-processor as the one TFM uses by default is nearly identical. Ordinarily, if using a different post-processor people use QTGMC or something else better than TDeint.
If nothing has to be post-processed then I suppose the encode goes very slightly faster.
Leftover combing/interlace artifacts?
By killerteengohan in forum RestorationReplies: 8Last Post: 24th Apr 2020, 19:11 -
By killerteengohan in forum RestorationReplies: 26Last Post: 12th Dec 2019, 21:01 -
How to deal with leftover combing after ivtc
By ZetaStax in forum Video ConversionReplies: 6Last Post: 4th Nov 2019, 11:11 -
AVISynth and TIVTC/TFM chokes on this clip, but why?
By SaurusX in forum Video ConversionReplies: 5Last Post: 8th May 2018, 17:06 -
QTGMC vs TFM for Progressive Source
By TheLastOfThem in forum Video ConversionReplies: 8Last Post: 26th Jul 2016, 06:52
