Hey,
i am tired and i didn't find any tutorials for this. So i keep this short and simple. How do i configure MPC HC + Mad VR + SVP Pro + Reclock to work. I am using 32 MPC HC 1.73 and than i installed SVP Pro, Mad Vr and Reclock got included in this. However source is 25 fps and i am trying to reclock to 24 so i have 144fps using SVP Pro. Yet i am getting 143.750. Reclock is running, everything has admin privileges. Not sure, why reclock doesn't do its thing. I tried various setting, but it doesn't work. One notable setting: there is option in Advanced settings to force reclock load instead of Mad Vr, while i want to use Mad Vr as video renderer, without this option Reclock doesn't even start. But Mad Vr is running as well, so i am confused. Again i am newbie in this and didn't find even one tutorial for this...
Also i am using DXVA 2 copy back as it is required for SVP Pro to work and ffdshow raw video filter. And i also set reclock by this guide, which isn't even much of a guide: https://www.avsforum.com/forum/26-home-theater-computers/1357375-advanced-mpc-hc-setup-guide.html
So hopefully this info helps. Besides i have feeling that it will be something else, because you just set target fps and that should be it, also it is complicated with combination of using SVP Pro, Mad Vr. It will probably be some setting, i don't know how these works together and found 0 info actually, which is strange.
I would appreciate if someone would tell me:
- how to reclock all videos to 24 fps+ audio ofc, so it is synced
- how to resize video to 2700x1400 etc. in MPC HC can't find this
Thanks very much!
Results 1 to 1 of 1
Reclock Force 60fps
By fohrums in forum Newbie / General discussionsReplies: 2Last Post: 26th Apr 2020, 10:12 -
Is there anything like ReClock for YouTube in Chrome?
By Phat J in forum Software PlayingReplies: 1Last Post: 4th Apr 2020, 16:44 -
madvr/mpchc and reclock (version?)
By box4m in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2019, 02:30 -
svp
By JekylHyde in forum Software PlayingReplies: 0Last Post: 9th Aug 2016, 17:12 -
Trying 64bit reclock
By beanies in forum Software PlayingReplies: 1Last Post: 10th Jul 2015, 08:23
