  1. Hi everyone,
    I need to rip the subtitles from an .mkv file
    As i am a newbie, please can you tell me if I am using the right program and with the right settings?
    From the information of the media in VLC, I learn that it is DVD Subtitles (spu).
    Info from CCExtractor:
    File seems to be a Matroska/WebM container
    Analyzing data in Matroska mode
    Matroska parser warning: You are using -out=<format>, but Matroska parser extract subtitles in a recorded format
    -out=<format> will be ignored
    Track entry:
        Track number: 8
        UID: 8
        Language: ita
        Codec ID: S_VOBSUB
        Type: subtitle
    I am running CCExtractor without any custom settings, I just dragged the file into the software:
    ccextractorwin.exe  --gui_mode_reports  -out=srt -bom -latin1 [+input files]
    this is the content of the output file that has the .(null) extension
    org: 0, 0
    scale: 100%, 100%
    alpha: 100%
    smooth: OFF
    fadein/out: 50, 50
    align: OFF at LEFT TOP
    time offset: 0
    forced subs: OFF
    palette: 000000, 000000, 000000, 000000, 000000, 000000, 000000, 000000, 000000, 000000, 000000, 000000, 000000, cbcbcb, 000000, 000000
    custom colors: OFF, tridx: 0000, colors: 000000, 000000, 000000, 000000
  2. Sorry, I forgot to upload a screen where you can see the subtitles I'm talking about ..
    https://forum.videohelp.com/attachment.php?attachmentid=53358&stc=1&d=1589821132
  3. Your subtitles IDX/VOBSUB format. You may extract them with MKVCleaver. But since you're aiming at .SRT format you need to do an OCR. You can drag the MKV file onto Subtitle Edit and the OCR will start .
  4. Directly .. in SubtitleEdit
    File->Import subtitle from Matroska (.mkv) file... 'ocr'
    責任者-MDX
