I installed AviSynth+ on an Azure Virtual Machine running Windows 10 (AviSynth+ 3.5.1 from https://github.com/AviSynth/AviSynthPlus/releases, Media Player Classic from https://www.codecguide.com/download_k-lite_codec_pack_mega.htm). I confirmed that the plugins folder at "C:\Program Files (x86)\AviSynth+\plugins64+" exists and I copied a plugin there.
I tested with a simple AVS script:
And it fails on Windows Media Player, whose bottom bar reads "Windows Media Player encountered a problem while playing the file" and on Media Player Classic, whose bottom bar reads "Cannot render the file". Neither displays any video content. The same happens after a restart.Code:Version()
The virtual machine was brand new and I tried twice, so I wonder if this is a problem of virtualization.
Has anyone succeeded running AviSynth+ on Azure?
Results 1 to 1 of 1
Universal Installer says 32-bit AviSynth is installed but fails to play
By miguelmorin in forum EditingReplies: 11Last Post: 22nd Apr 2020, 11:48 -
xilisoft audio convert fails
By bennyutzer in forum AudioReplies: 9Last Post: 2nd Oct 2017, 23:13 -
Azure Media Services Manifest
By jsvictor1989@gmail.com in forum Video Streaming DownloadingReplies: 0Last Post: 26th May 2017, 07:28 -
windows 10 - running installers under it fails ... [solved]
By vhelp in forum ComputerReplies: 5Last Post: 1st Dec 2015, 16:46 -
Avisynth - Anime Blu-ray with downscale fails
By Ninelpienel in forum EditingReplies: 15Last Post: 26th Aug 2015, 18:06
