Results 1 to 22 of 22
  1. Sample is attached. Everything about this has got me baffled. It seems to be progressive but has interlaced frames. I'd like to get rid of these blended frames so I can use it in Topaz
    SetMemoryMax(600)
    SetMTMode(2,4)
    directshowsource("C:\Users\cherb\Desktop\tmngwy ETV.demuxed.mkv", fps=59.94, framecount=14420)
    I've tried QTGMC with Inputtype 2 or 3 but the results are jerky.
  2. Please post a source sample (tmngwy ETV.demuxed.mkv)
  3. How do I split the MKV? I use DGIndex to demux the VOB and used MKVToolnix to create the MKV. I'm not sure how to split the MKV. I've enclosed a direct stream from the MKV in womble to M2V. No re-enocde. I'm assuming this is correct?
  4. you can us my clever FFmpeg-GUI to cut off a sample
  5. It required I convert to MP4
  6. Your footage is normal NTSC 29.97 interlaced, top field first, with regular 3:2 pulldown.
    You need to inverse telecine (IVTC) to 23.976.
    (Others can give you the avisynth commands as I no longer remember them.)
  7. Would it go something like
    AssumeTFF().QTGMC()
    Selecteven()
    TFM()
    Tdecimate()
  8. or
    directshowsource("C:\Users\cherb\Desktop\tmngwy ETV.demuxed.mkv")
    Assumetff().QTGMC(preset="slower", SourceMatch=2, Sharpness=0.0, TR2=0, Lossless=0, rep0=0, rep1=0,rep2=0, tr0=0, tr1=0, repchroma=false, MatchEnhance=0.00, chromaedi="Bob")
    Selecteven()
    TFM(pp=1, slow=2, d2v="C:\Users\cherb\Desktop\tmngwy ETV.d2v", order=-1)
    Tdecimate()
    I'm not sure if QTGMC is the correct usage in this situation so any feedback is much appreciated. Also if I try to open with FFMS2, I get gray frames occasionally and it opens 59.95
  9. No.
    Make a D2V project file using DGIndex and then use MPEG2Source on it. It's thoroughly explained in the DGMPGDec docs. Avoid using DirectShowSource if at all possible. Keep far away from MKV before encoding.
    It's a field-blended mess from a film source. You need a bobber followed by SRestore, something like:
    AssumeTFF()
    QTGMC()
    Srestore(Frate=23.976)
    It's far from perfect but better than any other solution.
  10. Srestore keeps returning that I need YUV colorspace even after converting to yv12?
  11. A DVD is already YV12. Did you somehow convert the colorspace along the way? What's the full script?
  12. No I didn't. I'm loading it directly from the d2v created in dgindex. Doesn't qtgmc have to be yuv? It loads just fine avspmod says rgb at the bottom though
  13. SetMemoryMax(600)
    SetMTMode(2,4)
    mpeg2source("C:\Users\cherb\Desktop\tmngwy ETV.d2v", cpu=0)
    #ConvertToYV12(interlaced=true, chromaresample="lanczos")
    Assumetff().QTGMC()
    Srestore()
  14. ITU-R BT.601 is what the original VOB from the DVD reads....unless DGindex converts to RGB?
  15. This what it says...looks like a Masktools error?
  16. Seems like it's being converted somewhere. In DGIndex, is Video-> YUV->RGB set to PC Scale, as it should be? If not, change it and make a new D2V file.
    If that's not it, try this. Stick an Info() command after each line after the MPEG2Source line, something like this:
    SetMemoryMax(600)
    SetMTMode(2,4)
    Info()
    #Assumetff().QTGMC()
    #Srestore()
    And then each line down from there until you find the culprit.
    Edit: By the way, I had to add the AssumeTFF line for your sample. There's a chance you might not need it for the full video. Put on a bobber alone and check you don't get that jerky back and forth stuff, indicative of an incorrect field order. AviSynth assumes BFF unless told otherwise.
  17. When I open the original VOB in Gspot in returns some really weird info. One of which is that it's field base is Per Pixel Frame? PPF. And yes it's set to Video-> YUV->RGB set to PC Scale. I just double checked to make sure. And following your instructions I get a YUV color space until Srestore then I get the same error I posted above that the color space is not correct
    Edit: masktools was the culprit. I fixed it
  18. That's good. One more source of frustration solved. There will be more.
  19. I would just QTGMC and encode at 59.94 fps.
  20. Originally Posted by jagabo View Post
    I thought about this as well and just leaving the blended frames...it will probably play smoother. And because this originated from a PAL source, I've changed the aspect ratio to match ffmpeg -i C:\Users\cherb\Desktop\tmngwy.avi -c copy -aspect 720/576 C:\Users\cherb\Desktop\tmngwy4.avi
  21. Originally Posted by Cherbette View Post
    And because this originated from a PAL source...i
    and unblended it to 23.976fps and not 25fps?
    Therefore your aspect ratio change is incorrect. And there's no way I'd just bob this and be done with it. Sure, there's one short scene full of blends even after being unblended. I didn't bother investigating whether it was intentional or, perhaps, the field order had changed again briefly. And the scene changes are a mess, typical of unblending. They can be fixed.
    If you consider blended frames as being helpful for smoother playing. I don't.
  22. I clearly am still on a learning curve lol. I tried with:
    AssumeTFF()
    QTGMC()
    but wasn't crazy about the result. The main thing is that QTGMC applies temporal filtration etc but I really need to disable these settings bc Topaz does this as well. I don't need it 2x. However when I disable all the filtration in QTGMC things start to look messy.
