can anyone tell me what the connector type is on the back of the wintv/pci card for tv-in? it's not a standard rf connector (although looks like a mini-sized version of one) and it's not an f-type connector (as in cable)... anyone know? also, i'm experiencing problems capturing from vhs due to poor quality tapes/recordings confusing the capture card. i don't want to goto the expense of a TBC... will connecting the vcr via the rf-out make a difference? (as it's simply an rf signal rather than composite video). cheers.
On my WinTV pci card, Model 404 it's just an RCA plug for video input. On later models I believe they have an S-video input for video. If you don't have S-Video out from your VCR (most standard VHS vcr's don't) you should have got with your WinTV card an adaptor to change the S-Video input to an RCA plug input.
Use S-Video if available. I have tried capturing using the normal RCA plug and I don't get good results.
Just bought WINTV-PVR-150 NTSC 26582, Composite input not yet working
By flemingdl in forum Capturing and VCRReplies: 6Last Post: 30th May 2011, 21:16 -
Questions about Hauppauge 1196 WinTV HVR-1250 PCI Express Card
By Wizard23 in forum Capturing and VCRReplies: 15Last Post: 25th Feb 2011, 15:22 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 00:21 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 11:58
