While new to all of this, I am having great success converting DivX files to VCD utilizing vcdhelp recommended freeware (VirtualDub, TMPGEnc, and Nero - came with my burner and has been upgraded to latest version). However, I have downloaded several avi files with "non-standard" frame speeds (14.9 fps, 20.0 fps, etc.) which are giving me problems. While I have no problem viewing these on computer using Windows Media Player, I have not been able to successfully burn onto VCD. I get audio, but no video (blank screen). I suspect there is a simple setting solution (perhaps in TMPEnc program) but I haven't found it yet. Any and all help will be appreciated. Thanks.
Basically, anything that has a non standard frame rate is a pain in the a**!!. Unless you are really keen it is probably not worth bothering with as the results are likley to be poor. If you still want to convert, then take a look at the guide for NTSC to PAL conversion, as many of the same basic rules will apply, only more so if you see what I mean.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 10:51 -
By Alexstarfire in forum Video ConversionReplies: 35Last Post: 22nd Aug 2007, 13:34 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15 -
DVD has (2) versions WS & std, how to back up only WS ver ?
By theewizard in forum DVD RippingReplies: 9Last Post: 6th Jun 2007, 16:00
