I didn't know you were suppose to only play for 10 seconds, and not rewind the tape. I let the tape play through and then rewound it. Did I really just destroy the head? I just bought this to convert videos and was about to start converting...
Unlikely to have ruined the heads, but did cause multiple hours of additional wear on the heads and drums because of the abrasive nature of the tape. Been there, done that.
Worse case scenario is that the tape shedded and clogged the heads. Been there, done that too! *SIGH* -
Phew, I was pretty frustrated. I am follow tutorials about alcohol swabbing the heads. After I used the cleaning tape the video got way worse. Should I buy another cleaning tape or follow these alcohol wipe videos?
It sounds like you've already caused possible permanent damage to the video heads. Try the alcohol and swabs (chamois or foam only, NOT Q-Tips or paper). Keep using a new section of the swab until they're clear of any residue.
Cleaning minidv tapes - cleaning machine available ?
By VideoEdwin in forum RestorationReplies: 2Last Post: 12th Dec 2019, 10:33 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 08:14 -
Cleaning PC
By Jomapil in forum ComputerReplies: 5Last Post: 10th Sep 2018, 19:47 -
Sony DCR-HC45 that don't record over the entire width of the tape
By edytibi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 14th May 2016, 10:33 -
Audio Issues Sony MiniDV Tape w/Sony DCR-HC46 cam
By tarana in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Aug 2015, 21:35
