  1. Is there a spec available for resolutions and formats supported by UHD Blu Ray?
  2. Member Cornucopia's Avatar
    Or get it straight from the source: Bluray Disc Association.
    But as far as resolutions supported, there is only ONE uhd resolution: 3840 x 2160. And ONE hd res: 1920 x 1080. All the other rezzes are applicable to BD but not UHD BD.
    And as far as formats are concerned, for video it is HEVC (both resolutions) or AVC (1080). That's it , the others are for BD discs only.
    For audio formats, it's the same as with BD but with the addition of DRA (& DRA-Extension).
