Hi,
When I convert my retail soccer-matches DVD's, the framerate is not acting like the original smooth one?
The original content looks as smooth as 60fps, but is onle 25fps.
When converting it with the same framerate, it looks like the framerate has dropped, although Mediainfo, says the same before and after converting? 25fps.
I use Handbrake, "same as source" framerate.
Maybe it has something to do with the content being interlaced, and I de-interlacing it while converting, using Handbrake's "fast" in "filters"?
It's pretty annoying.
Hope you guys can help
Ask for info-file, screenshot, videoclip, whatever
Best regards....
Results 1 to 15 of 15
Sorry, here:
[Attachment 53290 - Click to enlarge]
The file is untouched, just ripped with MakeMKV. -
You have to deinterlace.
Try my Qtgmc-GUI. Load your video, let create the script, encode with this settings: Framerate: Doubled, Field Order: BFF, CRF 23, DAR: 4:3
You need patience, it's slow.
https://forum.videohelp.com/threads/397026-Qtgmc-GUI-A-simple-encoder-for-your-Qtgmc-scripts -
I'm using 1.2.2 on Windows. I think your Bob will do the same thing as my Yadif+Bob. Be sure to select 50 fps on the Video tab.
The aforementioned QTGMC will get even better results. Smoother and less buzzing on near-horizontal edges.
changing ffmpeg framerate with " -r " not recognized?
By pxstein in forum Video ConversionReplies: 1Last Post: 21st Apr 2020, 08:23 -
Creating Mp4 "archival" content for Future Use (Win7 Capture, Xvid, Vdub)
By Tolwyn in forum Video ConversionReplies: 17Last Post: 5th May 2017, 14:16 -
What is the purpose of "Default" button in "Video" tab of XMedia Recode?
By MidnightUser in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2016, 04:08 -
How i can encode audio of "REMUX" to "BluRay.720p.DTS" wit handbrake?
By VideoHelp4Ever in forum Blu-ray RippingReplies: 1Last Post: 2nd Jul 2015, 12:41 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21
