Results 1 to 23 of 23
  1. Member koberulz's Avatar
    Oct 2006
    Australia
    I can rip an ISO or DVD folders just fine, but MakeMKV trips up and throws a LIBMKV_TRACE error which seems to be due to bad mastering.
    So...what are my options here? Ideally I'd have exactly what MakeMKV gives me, a completely lossless file which retains chapter points and such. As I say I can rip to an ISO or DVD folders, so the data is all there.
    Sep 2006
    I just googled your error and this was what came up for a solution: https://www.makemkv.com/forum/viewtopic.php?t=2494
    Try ripping with DVDFab or AnyDVD HD. You could also try using handbrake with libdvdcss.dll.
  3. Member koberulz's Avatar
    Oct 2006
    Australia
    Yeah, I found that thread as well. Pointing MakeMKV at the DVD folders ripped via AnyDVD failed too, as did attempting to rip without audio.
  4. Member koberulz's Avatar
    Oct 2006
    Australia
    Anyone?
    Feb 2006
    have you tried with dvdfab ??
  6. Member koberulz's Avatar
    Oct 2006
    Australia
    That's a bit outside my budget, especially for something that may or may not work.
    Feb 2006
    dvdfab has a 30 day free trial, after the 30 days are up the program
    reverts to the free HD Decrypter version.
  8. Member koberulz's Avatar
    Oct 2006
    Australia
    Reading a bit more, DVDFab just seems to be able to create ISO files or DVD Folders, which I already have.
    Jul 2007
    Haven't used DVDFab in years (use AnyDVD on the rare occasion I need to), but according to the site, it can remux to .mkv even in the free version. https://www.dvdfab.cn/dvd-ripper.htm?trackID=headmenu2
    The issue is that according to the MakeMKV forum link above, the issue is the audio track is malformed and if MakeMKV balks at that, so may DVDFab.
    I find the issue interesting and found a possible workaround, though again it may balk at the deformed audio track. If it does, you can try converting the audio into another format such as PCM or MPEG-1 Layer2. I think you can convert AC3 with Audicity.
    1. Remux the .iso or .ifo with MakeMKV, but exclude the audio track. Be sure to retain the chapters and subs.
    2. Demux the DVD (.ifo) with PgcDemux, by adding the main movie ifo. Choose the audio only since you have everything else in the .mkv from MakeMKV
    3. Remux the .mkv and audio with MKVToolNix.* There's a potential for an audio sync issue which you'll have to fix by adding or removing a delay with Audacity.
    *MKVToolNix won't accept the demuxed chapter and .sup files, audio only.
    I did a test and it worked (AFAIK) perfectly.
    Good luck and let us know if it works for you!
    Jul 2007
    Did you try excluding the audio from the ripped files like I suggested in my post above?
    If that doesn't work, read the following threads on how to replace the audio on a DVD.
    I forgot about those threads while trying to work it out on my own, stumbling through the process without the guidelines. The key in your case is that it's highly likely the audio that's malformed and you'll probably have to fix that to remux to .mkv.
  11. Member koberulz's Avatar
    Oct 2006
    Australia
    Excluding the audio in MakeMKV still fails, whether from a ripped ISO or from the original disc itself.
  12. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    What is the name of the movie? Have you downloaded the latest version of MakeMKV version 1.15.1 MakeMKV v1.15.1 (15.4.2020 )
    Added support for AACS v76 (for those poor souls without LibreDrive)
    Improved handling for discs with mastering errors
    Many internal improvements and small bugfixes
    Bug fixes:
    For some HD audio streams frames were dropped incorrectly on segment boundaries
    Jul 2007
    Yep, looking up LIBMKV_TRACE errors on the MakeMKV forum, it's either a program bug or mastering error. If the latest update doesn't work, post an error log to the MakeMKV forum as they're the ones who can fix it on the software side. It's possible the video or/and the audio is malformed or the pressing itself is bad.
    In the meantime, try DVDFab or demux with PGCDemux and remux with MKVToolNix.
    Edit: Also try different readers, to remove hardware as an issue.
  14. Member koberulz's Avatar
    Oct 2006
    Australia
    It's SummerSlam 1988 from the SummerSlam Anthology box set released in 2007. Every other disc in the set has ripped just fine.
  15. Member koberulz's Avatar
    Oct 2006
    Australia
    I don't have another drive but given the ISO ripped fine it seems unlikely.
    Updating MakeMKV didn't help either.
    Jul 2007
    Part of troubleshooting is being able to test and eliminate possibilities. I highly recommend having a spare drive for test purposes. The ripping part of MakeMKV, as you've experienced works very different from other programs, which BTW, you haven't said what you're using for straight rips. There's definitely something wrong with the disc or the reader you have since it's from 2007 and if it was a widespread issue, MakeMKV would have been updated to address it. BTW, have you played your rip all the way through? There could be some errors that your decrypter didn't report.
    I don't know about Australia, but I just saw some external DVD writers as low as $20 on Amazon. Over the decades I've been using PCs, I've learned to keep two of everything, I even have the parts to build a complete second i7 PC that I have to get around to, in addition to my laptop and dedicated video playing PC. This is especially critical now as you typically can't just drive out to store and pick up the parts you may need.
  17. Member koberulz's Avatar
    Oct 2006
    Australia
    PGCDemux did the job, but doesn't include the chapters.
  18. Member
    Jan 2019
    Europe
    Tried DVD Decrypter?
  19. Member koberulz's Avatar
    Oct 2006
    Australia
    I don't believe that even has an option to do what I'm trying to do.
  20. Member koberulz's Avatar
    Oct 2006
    Australia
    I tried ChapterXtractor to output the chapters in OGG format and use MKVToolnix's Chapter Editor to add them to the MKV file, but they seem off. They seem to start out alrightish, and then drift earlier and earlier relative to where they should be over the course of the file. Issues with the correct frame rate maybe?
    Here's the raw data from ChapterXtractor:
    Total film length : 02:28:49:90
    Chapter 1 = 00:00:00:00
    Chapter 2 = 00:00:21:20
    Chapter 3 = 00:02:26:03
    Chapter 4 = 00:24:38:76
    Chapter 5 = 00:27:41:76
    Chapter 6 = 00:35:59:43
    Chapter 7 = 00:37:28:96
    Chapter 8 = 00:47:02:60
    Chapter 9 = 00:48:32:96
    Chapter 10 = 00:58:45:03
    Chapter 11 = 01:06:50:13
    Chapter 12 = 01:13:07:93
    Chapter 13 = 01:20:33:46
    Chapter 14 = 01:21:38:53
    Chapter 15 = 01:35:16:60
    Chapter 16 = 01:36:28:86
    Chapter 17 = 01:44:59:23
    Chapter 18 = 01:46:10:33
    Chapter 19 = 02:03:41:93
    And the OGG file:
    CHAPTER01=00:00:00.000
    CHAPTER01NAME=Chapter 1
    CHAPTER02=00:00:21.200
    CHAPTER02NAME=Chapter 2
    CHAPTER03=00:02:26.034
    CHAPTER03NAME=Chapter 3
    CHAPTER04=00:24:38.768
    CHAPTER04NAME=Chapter 4
    CHAPTER05=00:27:41.768
    CHAPTER05NAME=Chapter 5
    CHAPTER06=00:35:59.435
    CHAPTER06NAME=Chapter 6
    CHAPTER07=00:37:28.968
    CHAPTER07NAME=Chapter 7
    CHAPTER08=00:47:02.601
    CHAPTER08NAME=Chapter 8
    CHAPTER09=00:48:32.968
    CHAPTER09NAME=Chapter 9
    CHAPTER10=00:58:45.034
    CHAPTER10NAME=Chapter 10
    CHAPTER11=01:06:50.134
    CHAPTER11NAME=Chapter 11
    CHAPTER12=01:13:07.934
    CHAPTER12NAME=Chapter 12
    CHAPTER13=01:20:33.467
    CHAPTER13NAME=Chapter 13
    CHAPTER14=01:21:38.533
    CHAPTER14NAME=Chapter 14
    CHAPTER15=01:35:16.600
    CHAPTER15NAME=Chapter 15
    CHAPTER16=01:36:28.866
    CHAPTER16NAME=Chapter 16
    CHAPTER17=01:44:59.233
    CHAPTER17NAME=Chapter 17
    CHAPTER18=01:46:10.333
    CHAPTER18NAME=Chapter 18
    CHAPTER19=02:03:41.933
    CHAPTER19NAME=Chapter 19
    I'm not sure how to calculate fractions of seconds for 29.97fps video so I'm not sure if those agree with each other.
    EDIT: Actually, despite using colons in the first list that appears to be fractions of a second too, so...never mind. Still not sure why the chapters lose sync, however.
    EDIT 2: Additionally, the file is actually 2:28:58, not 2:28:49.
    Jul 2007
    Another thought. You said MakeMKV won't work on an .iso or the original disc. Have you tried using it directly on the files extracted from the .iso? Just eliminating possibilities.
  22. Member
    Jul 2007
    A shot in the dark, but maybe the 100th/sec addition in the OGG file is cumulatively causing the sync error?
    If that doesn't work, suggest you start a new thread for the sync error as the major issue, remuxing to .mkv is solved and I'm the only one actively posting on this thread.
  23. Same issue here, Summer Slam 1988..
    Debug log:
    MakeMKV v1.16.5 win(x64-release) started
    Debug logging enabled, log will be saved as C:\Users\jerom/MakeMKV_log.txt
    Using direct disc access mode
    Title #1 was added (22 cell(s), 2:28:40)
    Operation successfully completed
    Saving 1 titles into directory C:/Convert/SUMMERSLAM_COLLECTION_1988
    DEBUG: Code 4294966024 at ;_f9#/b4hPJ&JP1#8pml:213143669
    DEBUG: Code 0 at ;_f9#/b4hPJ&JP1#8pml:213140702
    DEBUG: Code 0 at _Y+8iB|^MtysP|GFt:}V/:213137068
    DEBUG: Code 0 at 3B#\%:BlUEu3k2A;:213132537
    DEBUG: Code 0 at ?X91v,pcw_IIt^>v7:121264464
    DEBUG: Code 0 at ?X91v,pcw_IIt^>v7:121263912
    DEBUG: Code 0 at ?X91v,pcw_IIt^>v7:213130145
    LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
    Failed to save title 0 to file C:/Convert/SUMMERSLAM_COLLECTION_1988/title_t00.mkv
    0 titles saved, 1 failed
