I need information about this from people who are experienced. Is there any algorithm that does interpolation of the video in 1080p 30fps using the video in 720p 60fps? Of course, I'm talking about two footages of the same event.
Hypothetically, it can be done. But in practice, it isn't going to turn out as good as you hoped. On the contrary, you would have to be interpolating BOTH sources, and the error in those "guesses" don't necessarily cancel each other out.*
I recommend, barring finding a better source, you pick one (spatial priority = 1080, temporal priority = 720) and live with it.
*Note that you could try leaving the 1080 as is and just add in the alternate scaled-720 frames in a checkerboard fashion. However, if the positioning and/or the pixel brightness values aren't an exact match, you will get MAJOR, bothersome strobing artifacts.Last edited by Cornucopia; 12th May 2020 at 13:30.
How should I convert 1080p 30fps to 29.97fps
By VideoFanatic in forum RestorationReplies: 17Last Post: 21st Oct 2020, 07:48 -
For same bitrate which looks better between 720p and 1080p
By iKron in forum Newbie / General discussionsReplies: 34Last Post: 18th Dec 2019, 11:52 -
Mixing QHD p30 (2560x1440) and 1080p 50 fps clips in same project
By jayt123 in forum EditingReplies: 0Last Post: 15th Aug 2017, 00:34 -
Best Quality encoding from 1080p to 720p & 720p to 720p in Xvid4PSP?
By Odie111 in forum Video ConversionReplies: 8Last Post: 9th Jan 2016, 16:42 -
Do I need to resize 1080p PGS subs to 720p when making 720p AVCHD ???
By FulciLives in forum Authoring (Blu-ray)Replies: 3Last Post: 20th Aug 2015, 12:26
