Hi, I want to know if you know about such tool?
I know I probably can use mkvtoolnix to split the mka to certain time and join the same way but there is time loss in extracting the ac-3 from the mka, so, probably there is a tool to do this?
I don't want to re-encode the files as I would be lossing quality no matter what bitrate I set.
Thank you!
There's besplit, but it's a command line thing. There may be a GUI for it (Audio Cutter maybe?). Someone else might know.
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
but there is time loss in extracting the ac-3users currently on my ignore list: deadrats, Stears555, marcorocchini
I got MeGUI to split and join an MP3 to see how besplit works. MeGUI has an audio cutter, but it's not really what you need (I doubt) as it's designed to split and join audio based on video frame numbers, which it translates to times for the command line. Anyway... looking at the command lines MeGUI used to split an MP3 into sections and then append some of them into a single mp3 again, besplit is a command line nightmare. I'd rather do it with MKVToolNix.
Best free way to split or join .MP4 files?
By Nagashi in forum EditingReplies: 31Last Post: 15th Nov 2023, 23:16 -
hSplit - small command-line tool that lets you split and join files
By hubblec4 in forum EditingReplies: 4Last Post: 30th Sep 2020, 18:25 -
Split video by resolution and join after.
By Cauptain in forum EditingReplies: 12Last Post: 30th Apr 2018, 09:00 -
Seamlessly split/join frames
By PhoenixAZ in forum Newbie / General discussionsReplies: 5Last Post: 16th Mar 2017, 23:30 -
is this reliable method to join m2v? / VOB losslessly through mkvtoolnix
By efc1978 in forum EditingReplies: 15Last Post: 15th Sep 2016, 21:57
