I'm not sure if it's what you're after, but TDeint has a couple of blend de-interlacing modes, and SmoothDeinterlace has one also.
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
Thanks!
But the blend de-interlacing modes of TDeint have "blend" which are bad for the results.
My ripping software is x64.SmoothDeinterlace seems not siutable for me.
I just liked the style of text deinterlacing with linear blending.
I want to crop the text from the main picture to linear-blending,so I can deinterlace the rest part of pictures with other methods. -
You can linear blend deinterlace using a convolution filter. Masktools2 is probably fastest
Code:mt_convolution("1","1 2 1",chroma="process")
Blur(0.0, 1.0). I sometimes follow with (Sharpen(0.0, 0.6) to restore some sharpness to horizontal edges/lines, depending on the source.
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 11Last Post: 15th Dec 2021, 17:49 -
Equivalent of filter "Limiter" from Audacity in ffmpeg
By lenberg in forum AudioReplies: 1Last Post: 10th Oct 2018, 09:00 -
did I apply the filter syntax "-sws_flags bicubic" correctly?
By sommers in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2017, 21:13 -
FFMpeg : Use the "volume" filter for Preamp Equalizer setting ?
By alexander121 in forum AudioReplies: 0Last Post: 25th Jul 2015, 07:38 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21
