I need ffprobe to pass the width and height values to ffmpeg as I want it to automatically set the aspect ratio.
This is what I use to see what the rez is so far:
I drag the video file onto the bat file and it will print the width and height in the console. So far, so good, I can see it pulls the values correctly.Code:for %%i in ("%~nx1") do ( C:\ffmpeg-4.2.2-win32-static\bin\ffprobe.exe -v error -select_streams v:0 -show_entries stream=width,height -of csv=s=x:p=0 "%%i" )
But I need to pass it to ffmpeg so I can do a simple division to set the aspect ratio in ffmpeg command:
I dont know how to pass the ffprobe values to ffmpeg.Code:-aspect: width/height
Help appreciated.
Results 1 to 13 of 13
You have to read out the FFProbe-Output and copy the obtained Width/Height-Values to the FFmpeg-CommandLine.
To do it via a Script, use -report to print the Output to a Log-File.
Then parse that Log-File for the Video's Width&Height and copy them to Your FFmpeg-CommandLine.
For how to do it programmatically (what I like better), take a Look here:
http://forum.lazarus.freepascal.org/index.php/topic,43411.0.html
-> GoTo "RunFFmpeg".
This App is actually designed to run any Multimedia-Task with one App via the FFmpeg-CommandLine-Tools
'ffmpeg.exe', 'ffprobe.exe' and 'ffplay.exe'.
You may extract from the SourceCode whatever You need for Your Purpose (I'm the Author).
Or take my FFmpeg-Player, where You can adjust the AspectRatio (and all other VideoImage-Params) continuously, while
Watching a Video, thus time-consuming Transcoding is not needed any more:
https://forum.lazarus.freepascal.org/index.php/topic,26666.msg311955.html#msg311955
-> GoTo "Adapt any MRL to any Screen".
An other outstanding Feature of this Player is the optional AudioOutput via Portaudio, that
supports ASIO for low-latency real-time Audio, e.g. required for VJ-ing.
The Player there is still with 'SDL1'. Currently, I'm updating the entire Code to 'SDL2', The updated Version will work the same
Way, plus some more Features, like horizontal/vertical Flip and continuous Rotation of the Videoimage and Touchscreen-Support.
Hope, I could help You.
FFmpeg based FFPlay4Laz + FFGrab4Laz - RunFFmpeg. -
Well, if you use mediainfo, here's an alternative sample example
One could perhaps contemplate fetching other characteristics as well, egCode:set tempfile=.\tempfile.tmp set mediainfoexe=C:\software\mediainfo\mediainfo.exe set mp4_filename=sopme_mp4_file.mp4 Call :get_mediainfo_parameter "Video" "DisplayAspectRatio/String" "V_DisplayAspectRatio_String" "%~mp4_filename" set "V_DisplayAspectRatio_String_slash=!V_DisplayAspectRatio_String::=/! REM Now do something using variable "V_DisplayAspectRatio_String_slash!" REM eg ffmpeg ... -vf "setdar=!V_DisplayAspectRatio_String_slash!" ... exit REM get a parameter from mediainfo :get_mediainfo_parameter REM DO NOT SET @setlocal ENABLEDELAYEDEXPANSION REM DO NOT SET @setlocal enableextensions REM ensure no trailing spaces in any of the lines in this routine !! set mi_Section=%~1 set mi_Parameter=%~2 set mi_Variable=%~3 set mi_Filename=%~4 set "mi_var=" DEL /F "!tempfile!" >NUL 2>&1 REM Note \r\n is Windows new-line, which is for the case of multiple audio streams, REM it outputs a result for each stream on a new line, the first stream being the first entry, REM and the first audio stream should be the one we need. REM Set /p from an input file reads the first line. "!mediainfoexe!" "--Inform=!mi_Section!;%%!mi_Parameter!%%\r\n" "!mi_Filename!" > "!tempfile!" set /p mi_var=<"!tempfile!" set !mi_Variable!=!mi_var! REM ECHO !DATE! !TIME! "!mi_Variable!=!mi_var!" from "!mi_Section!" "!mi_Parameter!" REM ECHO !DATE! !TIME! "!mi_Variable!=!mi_var!" from "!mi_Section!" "!mi_Parameter!" DEL /F "!tempfile!" >NUL 2>&1 goto :eof
Code:Call :get_mediainfo_parameter_legacy "Video" "Codec" "V_Codec_legacy" "%~f1" Call :get_mediainfo_parameter_legacy "Video" "Format" "V_Format_legacy" "%~f1" REM Call :get_mediainfo_parameter_legacy "Audio" "Codec" "A_Codec_legacy" "%~f1" Call :get_mediainfo_parameter_legacy "Audio" "CodecID" "A_CodecID_legacy" "%~f1" Call :get_mediainfo_parameter_legacy "Audio" "Format" "A_Format_legacy" "%~f1" Call :get_mediainfo_parameter_legacy "Audio" "Video_Delay" "A_Video_Delay_ms_legacy" "%~f1" IF /I "!A_Video_Delay_ms_legacy!" == "" ( set /a "A_Audio_Delay_ms_legacy=0" ) ELSE ( set /a "A_Audio_Delay_ms_legacy=0 - !A_Video_Delay_ms_legacy!" ) ECHO !DATE! !TIME! "A_Video_Delay_ms_legacy=!A_Video_Delay_ms_legacy!" ECHO !DATE! !TIME! "A_Audio_Delay_ms_legacy=!A_Audio_Delay_ms_legacy!" Calculated REM Call :get_mediainfo_parameter "General" "VideoCount" "G_VideoCount" "%~f1" Call :get_mediainfo_parameter "General" "AudioCount" "G_AudioCount" "%~f1" Call :get_mediainfo_parameter "General" "Duration" "G_Duration_ms" "%~f1" Call :get_mediainfo_parameter "General" "Duration/String" "G_Duration_String" "%~f1" Call :get_mediainfo_parameter "General" "Duration/String1" "G_Duration_String1" "%~f1" Call :get_mediainfo_parameter "General" "Duration/String2" "G_Duration_String2" "%~f1" Call :get_mediainfo_parameter "General" "Duration/String3" "G_Duration_String3" "%~f1" Call :get_mediainfo_parameter "General" "Duration/String4" "G_Duration_String4" "%~f1" Call :get_mediainfo_parameter "General" "Duration/String5" "G_Duration_String5" "%~f1" Call :get_mediainfo_parameter "General" "Duration_Start" "G_Start" "%~f1" Call :get_mediainfo_parameter "General" "Duration_End" "G_End" "%~f1" REM Call :get_mediainfo_parameter "Video" "CodecID" "V_CodecID" "%~f1" Call :get_mediainfo_parameter "Video" "CodecID/String" "V_CodecID_String" "%~f1" Call :get_mediainfo_parameter "Video" "Format" "V_Format" "%~f1" Call :get_mediainfo_parameter "Video" "Format/String" "V_Format_string" "%~f1" Call :get_mediainfo_parameter "Video" "Format_Version" "V_Format_Version" "%~f1" Call :get_mediainfo_parameter "Video" "Format_Profile" "V_Format_Profile" "%~f1" Call :get_mediainfo_parameter "Video" "Format_Level" "V_Format_Level" "%~f1" Call :get_mediainfo_parameter "Video" "Format_Tier" "V_Format_Tier" "%~f1" Call :get_mediainfo_parameter "Video" "Format_Compression" "V_Format_Compression" "%~f1" Call :get_mediainfo_parameter "Video" "Format_Commercial" "V_Format_Commercial" "%~f1" Call :get_mediainfo_parameter "Video" "Format_Commercial_IfAny" "V_Format_Commercial_IfAny" "%~f1" Call :get_mediainfo_parameter "Video" "StreamKind" "V_StreamKind" "%~f1" Call :get_mediainfo_parameter "Video" "StreamKind/String" "V_StreamKind_String" "%~f1" Call :get_mediainfo_parameter "Video" "InternetMediaType" "V_InternetMediaType" "%~f1" Call :get_mediainfo_parameter "Video" "Duration" "V_Duration_ms" "%~f1" Call :get_mediainfo_parameter "Video" "Duration/String" "V_Duration_ms_String" "%~f1" Call :get_mediainfo_parameter "Video" "Duration/String1" "V_Duration_ms_String1" "%~f1" Call :get_mediainfo_parameter "Video" "Duration/String2" "V_Duration_ms_String2" "%~f1" Call :get_mediainfo_parameter "Video" "Duration/String3" "V_Duration_ms_String3" "%~f1" Call :get_mediainfo_parameter "Video" "Duration/String4" "V_Duration_ms_String4" "%~f1" Call :get_mediainfo_parameter "Video" "Duration/String5" "V_Duration_ms_String5" "%~f1" Call :get_mediainfo_parameter "Video" "Duration_Start" "V_Duration_Start" "%~f1" Call :get_mediainfo_parameter "Video" "Duration_End" "V_Duration_End" "%~f1" REM Call :get_mediainfo_parameter "Video" "Source_Duration" "V_Source_Duration_ms" "%~f1" Call :get_mediainfo_parameter "Video" "Source_Duration/String" "V_Source_Duration_ms_String" "%~f1" Call :get_mediainfo_parameter "Video" "Source_Duration/String1" "V_Source_Duration_ms_String1" "%~f1" Call :get_mediainfo_parameter "Video" "Source_Duration/String2" "V_Source_Duration_ms_String2" "%~f1" Call :get_mediainfo_parameter "Video" "Source_Duration/String3" "V_Source_Duration_ms_String3" "%~f1" Call :get_mediainfo_parameter "Video" "Source_Duration/String4" "V_Source_Duration_ms_String4" "%~f1" Call :get_mediainfo_parameter "Video" "Source_Duration/String5" "V_Source_Duration_ms_String5" "%~f1" Call :get_mediainfo_parameter "Video" "Source_Duration_Start" "V_Source_Duration_Start" "%~f1" Call :get_mediainfo_parameter "Video" "Source_Duration_End" "V_Source_Duration_End" "%~f1" REM Call :get_mediainfo_parameter "Video" "BitRate_Mode" "V_BitRate_Mode" "%~f1" Call :get_mediainfo_parameter "Video" "BitRate_Mode/String" "V_BitRate_Mode_String" "%~f1" Call :get_mediainfo_parameter "Video" "BitRate" "V_BitRate" "%~f1" Call :get_mediainfo_parameter "Video" "BitRate/String" "V_BitRate_String" "%~f1" Call :get_mediainfo_parameter "Video" "BitRate_Minimum" "V_BitRate_Minimum" "%~f1" Call :get_mediainfo_parameter "Video" "BitRate_Minimum/String" "V_BitRate_Minimum_String" "%~f1" Call :get_mediainfo_parameter "Video" "BitRate_Maximum" "V_BitRate_Maximum" "%~f1" Call :get_mediainfo_parameter "Video" "BitRate_Maximum/String" "V_BitRate_Maximum_String" "%~f1" Call :get_mediainfo_parameter "Video" "BufferSize" "V_BufferSize" "%~f1" Call :get_mediainfo_parameter "Video" "Bits-(Pixel*Frame)" "V_Bits_Pixel_Frame" "%~f1" Call :get_mediainfo_parameter "Video" "BitDepth" "V_BitDepth" "%~f1" Call :get_mediainfo_parameter "Video" "BitDepth/String" "V_BitDepth_String" "%~f1" Call :get_mediainfo_parameter "Video" "Width" "V_Width" "%~f1" Call :get_mediainfo_parameter "Video" "Height" "V_Height" "%~f1" Call :get_mediainfo_parameter "Video" "Stored_Width" "V_Stored_Width" "%~f1" Call :get_mediainfo_parameter "Video" "Stored_Height" "V_Stored_Height" "%~f1" Call :get_mediainfo_parameter "Video" "PixelAspectRatio" "V_PixelAspectRatio" "%~f1" Call :get_mediainfo_parameter "Video" "PixelAspectRatio/String" "V_PixelAspectRatio_String" "%~f1" Call :get_mediainfo_parameter "Video" "PixelAspectRatio_Original" "V_PixelAspectRatio_Original" "%~f1" Call :get_mediainfo_parameter "Video" "PixelAspectRatio_Original/String" "V_PixelAspectRatio_Original_String" "%~f1" Call :get_mediainfo_parameter "Video" "DisplayAspectRatio" "V_DisplayAspectRatio" "%~f1" Call :get_mediainfo_parameter "Video" "DisplayAspectRatio/String" "V_DisplayAspectRatio_String" "%~f1" set "V_DisplayAspectRatio_String_slash=!V_DisplayAspectRatio_String::=/!" Call :get_mediainfo_parameter "Video" "DisplayAspectRatio_Original" "V_DisplayAspectRatio_Original" "%~f1" Call :get_mediainfo_parameter "Video" "DisplayAspectRatio_Original/String" "V_DisplayAspectRatio_Original_String" "%~f1" Call :get_mediainfo_parameter "Video" "Rotation" "V_Rotation" "%~f1" Call :get_mediainfo_parameter "Video" "Rotation/String" "V_Rotation_String" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Mode" "V_FrameRate_Mode" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Mode/String" "V_FrameRate_Mode_String" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Mode_Original" "V_FrameRate_Mode_Original" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Mode_Original/String" "V_FrameRate_Mode_Original_String" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate" "V_FrameRate" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate/String" "V_FrameRate_String" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Minimum" "V_FrameRate_Minimum" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Minimum/String" "V_FrameRate_Minimum_String" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Nominal" "V_FrameRate_Nominal" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Nominal/String" "V_FrameRate_Nominal_String" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Maximum" "V_FrameRate_Maximum" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Maximum/String" "V_FrameRate_Maximum_String" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Original" "V_FrameRate_Original" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Original/String" "V_FrameRate_Original_String" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Num" "V_FrameRate_Num" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Den" "V_FrameRate_Den" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Original_Num" "V_FrameRate_Original_Num" "%~f1" Call :get_mediainfo_parameter "Video" "FrameRate_Original_Den" "V_FrameRate_Original_Den" "%~f1" REM Call :get_mediainfo_parameter "Video" "FrameCount" "V_FrameCount" "%~f1" Call :get_mediainfo_parameter "Video" "Source_FrameCount" "V_Source_FrameCount" "%~f1" Call :get_mediainfo_parameter "Video" "Standard" "V_Standard" "%~f1" REM Call :get_mediainfo_parameter "Video" "ColorSpace" "V_ColorSpace" "%~f1" Call :get_mediainfo_parameter "Video" "ChromaSubsampling" "V_ChromaSubsampling" "%~f1" Call :get_mediainfo_parameter "Video" "ChromaSubsampling/String" "V_ChromaSubsampling_String" "%~f1" Call :get_mediainfo_parameter "Video" "ChromaSubsampling_Position" "V_ChromaSubsampling_Position" "%~f1" Call :get_mediainfo_parameter "Video" "Gop_OpenClosed" "V_Gop_OpenClosed" "%~f1" Call :get_mediainfo_parameter "Video" "Gop_OpenClosed/String" "V_Gop_OpenClosed_String" "%~f1" REM Call :get_mediainfo_parameter "Video" "ScanType" "V_ScanType" "%~f1" Call :get_mediainfo_parameter "Video" "ScanType/String" "V_ScanType_String" "%~f1" Call :get_mediainfo_parameter "Video" "ScanType_Original" "V_ScanType_Original" "%~f1" Call :get_mediainfo_parameter "Video" "ScanType_Original/String" "V_ScanType_Original_String" "%~f1" Call :get_mediainfo_parameter "Video" "ScanType_StoreMethod" "V_ScanType_StoreMethod" "%~f1" Call :get_mediainfo_parameter "Video" "ScanType_StoreMethod_FieldsPerBlock" "V_ScanType_StoreMethod_FieldsPerBlock" "%~f1" Call :get_mediainfo_parameter "Video" "ScanType_StoreMethod/String" "V_ScanType_StoreMethod_String" "%~f1" IF /I "!V_ScanType!" == "" ( ECHO !DATE! !TIME! "V_ScanType blank, setting V_ScanType=Progressive" ECHO !DATE! !TIME! "V_ScanType blank, setting V_ScanType=Progressive" set "V_ScanType=Progressive" ) IF /I "!V_ScanType!" == "MBAFF" ( ECHO !DATE! !TIME! "V_ScanType blank, setting V_ScanType=Interlaced" ECHO !DATE! !TIME! "V_ScanType blank, setting V_ScanType=Interlaced" set "V_ScanType=Interlaced" ) Call :get_mediainfo_parameter "Video" "ScanOrder" "V_ScanOrder" "%~f1" Call :get_mediainfo_parameter "Video" "ScanOrder/String" "V_ScanOrder_String" "%~f1" Call :get_mediainfo_parameter "Video" "ScanOrder_Stored" "V_ScanOrder_Stored" "%~f1" Call :get_mediainfo_parameter "Video" "ScanOrder_Stored/String" "V_ScanOrder_Stored_String" "%~f1" Call :get_mediainfo_parameter "Video" "ScanOrder_StoredDisplayedInverted" "V_ScanOrder_StoredDisplayedInverted" "%~f1" Call :get_mediainfo_parameter "Video" "ScanOrder_Original" "V_ScanOrder_Original" "%~f1" Call :get_mediainfo_parameter "Video" "ScanOrder_Original/String" "V_ScanOrder_Original_String" "%~f1" IF /I "!V_ScanOrder!" == "" ( ECHO !DATE! !TIME! "V_ScanOrder blank, setting V_ScanOrder=TFF" ECHO !DATE! !TIME! "V_ScanOrder blank, setting V_ScanOrder=TFF" set "V_ScanOrder=TFF" ) Call :get_mediainfo_parameter "Video" "HDR_Format" "V_HDR_Format" "%~f1" Call :get_mediainfo_parameter "Video" "HDR_Format/String" "V_HDR_Format_String" "%~f1" Call :get_mediainfo_parameter "Video" "HDR_Format_Commercial" "V_HDR_Format_Commercial" "%~f1" Call :get_mediainfo_parameter "Video" "HDR_Format_Version" "V_HDR_Format_Version" "%~f1" Call :get_mediainfo_parameter "Video" "HDR_Format_Profile" "V_HDR_Format_Profile" "%~f1" Call :get_mediainfo_parameter "Video" "HDR_Format_Level" "V_HDR_Format_Level" "%~f1" Call :get_mediainfo_parameter "Video" "HDR_Format_Settings" "V_HDR_Format_Settings" "%~f1" Call :get_mediainfo_parameter "Video" "HDR_Format_Compatibility" "V_HDR_Format_Compatibility" "%~f1" REM Call :get_mediainfo_parameter "Video" "colour_description_presence" "V_colour_description_presence" "%~f1" Call :get_mediainfo_parameter "Video" "colour_range" "V_colour_range" "%~f1" Call :get_mediainfo_parameter "Video" "colour_range_Source" "V_colour_range_Source" "%~f1" Call :get_mediainfo_parameter "Video" "colour_range_Original" "V_colour_range_Original" "%~f1" Call :get_mediainfo_parameter "Video" "colour_range_Original_Source" "V_colour_range_Original_Source" "%~f1" Call :get_mediainfo_parameter "Video" "colour_primaries" "V_colour_primaries" "%~f1" Call :get_mediainfo_parameter "Video" "colour_primaries_Source" "V_colour_primaries_Source" "%~f1" Call :get_mediainfo_parameter "Video" "colour_primaries_Original" "V_colour_primaries_Original" "%~f1" Call :get_mediainfo_parameter "Video" "colour_primaries_Original_Source" "V_colour_primaries_Original_Source" "%~f1" Call :get_mediainfo_parameter "Video" "transfer_characteristics" "V_transfer_characteristics" "%~f1" Call :get_mediainfo_parameter "Video" "transfer_characteristics_Source" "V_transfer_characteristics_Source" "%~f1" Call :get_mediainfo_parameter "Video" "matrix_coefficients" "V_matrix_coefficients" "%~f1" Call :get_mediainfo_parameter "Video" "matrix_coefficients_Source" "V_matrix_coefficients_Source" "%~f1" Call :get_mediainfo_parameter "Video" "MasteringDisplay_ColorPrimaries" "V_MasteringDisplay_ColorPrimaries" "%~f1" Call :get_mediainfo_parameter "Video" "MasteringDisplay_ColorPrimaries_Source" "V_MasteringDisplay_ColorPrimaries_Source" "%~f1" Call :get_mediainfo_parameter "Video" "MasteringDisplay_Luminance" "V_MasteringDisplay_Luminance" "%~f1" Call :get_mediainfo_parameter "Video" "MasteringDisplay_Luminance_Source" "V_MasteringDisplay_Luminance_Source" "%~f1" Call :get_mediainfo_parameter "Video" "MaxCLL" "V_MaxCLL" "%~f1" Call :get_mediainfo_parameter "Video" "MaxCLL_Source" "V_MaxCLL_Source" "%~f1" Call :get_mediainfo_parameter "Video" "MaxCLL_Original" "V_MaxCLL_Original" "%~f1" Call :get_mediainfo_parameter "Video" "MaxCLL_Original_Source" "V_MaxCLL_Original_Source" "%~f1" Call :get_mediainfo_parameter "Video" "MaxFALL" "V_MaxFALL" "%~f1" Call :get_mediainfo_parameter "Video" "MaxFALL_Source" "V_MaxFALL_Source" "%~f1" Call :get_mediainfo_parameter "Video" "MaxFALL_Original" "V_MaxFALL_Original" "%~f1" Call :get_mediainfo_parameter "Video" "MaxFALL_Original_Source" "V_MaxFALL_Original_Source" "%~f1" REM Call :get_ffprobe_video_stream_parameter "codec_name" "V_CodecID_FF" "%~f1" Call :get_ffprobe_video_stream_parameter "codec_tag_string" "V_CodecID_String_FF" "%~f1" Call :get_ffprobe_video_stream_parameter "width" "V_Width_FF" "%~f1" Call :get_ffprobe_video_stream_parameter "height" "V_Height_FF" "%~f1" Call :get_ffprobe_video_stream_parameter "duration" "V_Duration_s_FF" "%~f1" Call :get_ffprobe_video_stream_parameter "bit_rate" "V_BitRate_FF" "%~f1" Call :get_ffprobe_video_stream_parameter "max_bit_rate" "V_BitRate_Maximum_FF" "%~f1" REM Call :get_mediainfo_parameter "Audio" "CodecID" "A_CodecID" "%~f1" Call :get_mediainfo_parameter "Audio" "CodecID/String" "A_CodecID_String" "%~f1" Call :get_mediainfo_parameter "Audio" "Video_Delay" "A_Video_Delay_ms" "%~f1" IF /I "!A_Video_Delay_ms!" == "" ( set /a A_Audio_Delay_ms=0 ) ELSE ( set /a A_Audio_Delay_ms=0 - !A_Video_Delay_ms! ) ECHO !DATE! !TIME! "A_Video_Delay_ms=!A_Video_Delay_ms!" ECHO !DATE! !TIME! "A_Audio_Delay_ms=!A_Audio_Delay_ms!" Calculated REM Call :get_mediainfo_parameter "Audio" "Video_Delay/String" "A_Video_Delay_String" "%~f1" Call :get_mediainfo_parameter "Audio" "Video_Delay/String1" "A_Video_Delay_String1" "%~f1" Call :get_mediainfo_parameter "Audio" "Video_Delay/String2" "A_Video_Delay_String2" "%~f1" Call :get_mediainfo_parameter "Audio" "Video_Delay/String3" "A_Video_Delay_String3" "%~f1" Call :get_mediainfo_parameter "Audio" "Video_Delay/String4" "A_Video_Delay_String4" "%~f1" Call :get_mediainfo_parameter "Audio" "Video_Delay/String5" "A_Video_Delay_String5" "%~f1" Call :get_mediainfo_parameter "Audio" "InternetMediaType" "A_InternetMediaType" "%~f1" Call :get_mediainfo_parameter "Audio" "Format" "A_Format" "%~f1" Call :get_mediainfo_parameter "Audio" "Format/String" "A_Format_String" "%~f1" Call :get_mediainfo_parameter "Audio" "Format/Info" "A_Format_Info" "%~f1" Call :get_mediainfo_parameter "Audio" "Format_Commercial" "A_Format_Commercial" "%~f1" Call :get_mediainfo_parameter "Audio" "Format_Commercial_IfAny" "A_Format_Commercial_IfAny" "%~f1" Call :get_mediainfo_parameter "Audio" "Format_Version" "A_Format_Version" "%~f1" Call :get_mediainfo_parameter "Audio" "Format_Profile" "A_Format_Profile" "%~f1" Call :get_mediainfo_parameter "Audio" "Format_Level" "A_Format_Level" "%~f1" Call :get_mediainfo_parameter "Audio" "Format_Compression" "A_Format_Compression" "%~f1" Call :get_mediainfo_parameter "Audio" "Channel(s)" "A_Channels" "%~f1" Call :get_mediainfo_parameter "Audio" "Channel(s)/String" "A_Channels_String" "%~f1"
Oh.
The original post is dated yonks ago.
Never mind, the info is there for posterity anyway. -
@ hydra3333
This Subject/Question exists since there is 'FFmpeg'.The original post is dated yonks ago.
At least, Bassquake (and maybe others) now got an Idea to get it solved.
A Forum is a Repository, as well. Otherwise, any elder Thread could be deleted.
I find its easier to use MediaInfo:
Result:Code:::@ echo off "MediaInfo.exe" --inform=Video;%%Width%% "C:\Users\bud\Desktop\xInstagram.mp4" > "C:\Users\bud\Desktop\test.txt" set /p width= < "C:\Users\bud\Desktop\test.txt" "MediaInfo.exe" --inform=Video;%%Height%% "C:\Users\bud\Desktop\xInstagram.mp4" > "C:\Users\bud\Desktop\test.txt" set /p height= < "C:\Users\bud\Desktop\test.txt" echo resolution is: %width%x%height% "ffmpeg" -i "C:\Users\bud\Desktop\xInstagram.mp4" -vf scale=%width%:%height% outputtt.mp4
resolution is: 1152x648
and file outputtt.mp4
Media Info gets video attribute and pipes it to test.txt then imports to set each variable.
Use the variable how you wish for ffmpeg. Here I have just used it to output another video with height and width specifications
Use double %% for cmd file mediainfo part. Single % for ffmpeg cmd variables
Be VERY careful with Capitalization and quotes. Height works, height doesn't. MediaInfo is fussy that way. -
And to do it (still) with FFProbe and -show_entries, see here:
StackExchange: How to use ffprobe to obtain certain information about mp4/h.264 files
and
FFmpeg-Wiki: FFProbe-Tips
-> GoTo "Width x Height (resolution)".FFmpeg based FFPlay4Laz + FFGrab4Laz - RunFFmpeg. -
Here's how you can get the width and height into separate environment variables using ffprobe (similar to the MediaInfoCLI technique):
Code:@echo off ffprobe.exe -v quiet -show_entries stream=width -of default=noprint_wrappers=1:nokey=1 -select_streams v:0 %1 > %1.txt set /p width= < %1.txt ffprobe.exe -v quiet -show_entries stream=height -of default=noprint_wrappers=1:nokey=1 -select_streams v:0 %1 > %1.txt set /p height= < %1.txt del %1.txt REM At this point the environment variables "width" and "height" are available to your ffmpeg command line. REM for example, to scale to half width and half height: ffmpeg -i %1 -vf scale=%width%/2:%height%/2 output.mkv
Thanks. I had a go.
unfortunately it seems batch files only seems to support integers. I needed to divide the width and height to give decimal numbers for ffmpegs -aspect: tag. It will only give 1 rather than 1.277.
Also doesnt work on avs scripts.
Oh well, was worth a try.
This was what I tried:
Code:@echo off ffprobe.exe -v quiet -show_entries stream=width -of default=noprint_wrappers=1:nokey=1 -select_streams v:0 %1 > %1.txt set /p width= < %1.txt ffprobe.exe -v quiet -show_entries stream=height -of default=noprint_wrappers=1:nokey=1 -select_streams v:0 %1 > %1.txt set /p height= < %1.txt set a=%width% set b=%height% set /a ratio=a/b REM At this point the environment variables "width" and "height" are available to your ffmpeg command line. REM for example, to scale to half width and half height: ffmpeg -i %1 -aspect: %ratio% output.mkv pause
I added information to my last post about how you can pass environment variables to AVS script.
Create 2-pass videos using ffmpeg & python
By olpdog in forum EditingReplies: 0Last Post: 29th Jun 2019, 21:16 -
ffmpeg vs ffprobe frame count speed
By Anime4000 in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2019, 05:05 -
Pass Xvfb directly to ffmpeg
By mario90yxz in forum Video ConversionReplies: 0Last Post: 8th Jan 2018, 09:04 -
Please help on my 2-pass (Windows) ffmpeg cmd (SOLVED)
By SameSelf in forum Video ConversionReplies: 2Last Post: 26th May 2017, 12:41 -
Two-Pass Encoding using AVS2YUV with FFmpeg
By wwaag in forum Video ConversionReplies: 10Last Post: 9th Mar 2017, 17:33
