Hi folks,
I have a few dozen D8 tapes that I'd like to capture as QT files and archive to a hard drive. What is an inexpensive way to do this? "Inexpensive" to me means <$200. I've seen some D8 players on eBay. Is this a good option?
Thanks!
Keith
You need a decent, working Digital 8 player -- either deck or camera, a firewire card, and the appropriate cabling.
I'm seeing prices around $300 for cameras and $600 for decks, so your budget is probably low. -
Well then that's what I'll have to do. (The $300 option of course is better.) Thank you for providing the info.
K -
I needed a way to transfer all 8mm formats, including Digital8. After quite a bit of research several years ago, the make and model that everyone seemed to recommend was the Sony DCR-TRV110. I found a NIB model on eBay, bought it, and transferred all three 8mm formats. It worked incredibly well.
I'm seeing a bunch of TRV models on eBay as I type this. And, they're inexpensive. I think this is the best way to go for this.
Yes, thank you. No, I know the difference between Hi-8 and D-8. I won't make that mistake. No, these are digital-8 cameras.
Thanks John. -
If all you want to do is transfer Digital8, then the video is stored as a digital file on the tape and so all you need is a machine that can play the tape. So in theory any camcorder that is a D8 machine that still functions would work. Without all the intricacy of optimal analog capturing. Also stop making duplicate threads on the same topic back to back.
Digitizing VHS Cassettes
By Kong in forum Newbie / General discussionsReplies: 21Last Post: 12th May 2020, 22:35 -
Trying to convert old 8mm video cassettes to digital
By Billymax in forum Newbie / General discussionsReplies: 11Last Post: 16th Aug 2019, 06:19 -
Cassettes to mp3 best free converter ?
By Arcadiune in forum AudioReplies: 21Last Post: 2nd Mar 2019, 15:50 -
Audio from Cassettes Audacity Issue
By creaper in forum AudioReplies: 3Last Post: 17th Jul 2018, 23:46 -
audio cassettes to mp3 convert help
By vidyarathne in forum AudioReplies: 4Last Post: 25th Aug 2017, 05:11
