Hello everyone, as the title says I'm trying to find a way to use ffmpeg to take a screenshot from lots of mkv files inside folders that are inside a main folder. I'd like the screenshot to be taken at, let's say, 10 minutes from the start of each video and to be named as the filename to which it refers. Is ffmpeg the right software to achieve this? I think it is since after googling how to batch screenshot I stumbled upon this question (https://stackoverflow.com/questions/12084875/) and the relative article that suggests to use it, but I'm not sure it answers entirely to what I want to achieve and since I've never used ffmpeg before I don't know how to modify that to work as I want.
Thanks in advance![]()
Hello, just a quick update, I found what I wanted! It's https://www.videohelp.com/software/Auto-Movie-Thumbnailer
idk if you close the topic after the question has been answered, but in case you can close this one :>
How to batch convert/multiplex any files with ffmpeg
By Baldrick in forum User guidesReplies: 215Last Post: 1st Dec 2023, 11:38 -
ffmpeg - How to batch screen grab from multiple video files?
By Gameshow Host in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2019, 07:04 -
(Help Needed with ffmpeg) how do i batch merge audio files to video files
By wander799 in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2016, 14:40 -
Need help with ffmpeg script to batch convert audio in MKV files
By mikeveli20 in forum AudioReplies: 5Last Post: 18th Nov 2016, 13:21 -
Having issues batch converting raw .264 cctv files with FFMPEG-
By raidecker22 in forum Video ConversionReplies: 11Last Post: 22nd Aug 2015, 14:58
