Results 1 to 12 of 12
  1. I downloaded a video from Dailymotion and it is flipped? How do I make it the right way round? See jpg below
Name:	ASS BACKWARDS.JPG
  2. You can flip it horizontally
    eg.
    -vf "hflip" in ffmpeg
    or
    FlipHorizontal() in avisynth
    or
    avidemux has a horizontal flip filter
    all require re-encoding
  3. Try exiftool
    -orientation#=2
    From exiftool documentation
    1 = Horizontal (normal)
    2 = Mirror horizontal
    3 = Rotate 180
    4 = Mirror vertical
    5 = Mirror horizontal and rotate 270 CW
    6 = Rotate 90 CW
    7 = Mirror horizontal and rotate 90 CW
    8 = Rotate 270 CW
  4. The following worked for me using vlc to play the video rotated 180 degrees (requires re-encoding):
    ffmpeg -i input.mp4 -vf "transpose=2,transpose=2" output.mp4
    does not require re-encoding (rotated 180, 90, -90)
    ffmpeg -i input.mp4 -c copy -metadata:s:v:0 rotate=180 output.mp4
    ffmpeg -i input.mp4 -c copy -metadata:s:v:0 rotate=90 output.mp4
    ffmpeg -i input.mp4 -c copy -metadata:s:v:0 rotate=-90 output.mp4
    Also, (requires re-encoding) rotate 90 degrees:
    ffmpeg -i input.mp4 -vf "transpose=1" output.mp4
    And, (requires re-encoding) rotate minus 90 degrees:
    ffmpeg -i input.mp4 -vf "transpose=2" output.mp4
    Create mirror image (requires re-encoding)
     ffmpeg -i input.mp4 -qscale 2 -vf "hflip" output.mp4
  5. locotus
    May 2011
    Cypress, Tx.
    This may seem silly, but if not a very long video, just face your monitor to a mirror and watch the video through it.
    Oct 2005
    666th portal
    really? about the dumbest thing ever suggested here and that's saying a lot...
  7. locotus
    May 2011
    Cypress, Tx.
    https://en.wikipedia.org/wiki/Mirror_writing
  8. You don't have to do any of the things suggested. Just tell your player to flip it. For VLC, here are the instructions:
    How to Rotate and Flip a Video in VLC Media Player
    I just tried it and it works perfectly. It took less than ten seconds to find and set the "flip horizontal" function, and I didn't have to deal with command lines, and didn't have to re-encode anything.
  9. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Just about any video editor can do it if you want to make a permanent copy
  10. Member darkknight145's Avatar
    Feb 2007
    Australia
    As others have said, just flip it in your player, if you want to keep it (although I don't know why, it's low res) you can do a screen record from your player (potplayer can do this).
    The reason it's probably reversed is the uploader was trying to circumvent YouTube piracy detection.
  11. The reason it's probably reversed is the uploader was trying to circumvent YouTube piracy detection.
    Interesting comment.
    I think the rotating might be useful if someone took a video with their smartphone, and held the phone the wrong way, and wanted to send the video to another person.
  12. It's not rotated. It's horizontally flipped.
