My LG blu ray writer has suddenly developed a problem burring data to verbatim 25 gb BD-r discs
I bought a new pack of BD-R discs and still the same problem
Any suggestions Please
9053-0180-TLXU-8XK2-6A66-E3LW-****-****
Windows 8 6.2
AMD64
Wow64Process
Nero Version: 16.0.21.0
Internal Version: 16,0,21,0
(Nero Express)
Recorder : <HL-DT-ST BD-RE WH14NS40> FW version: 1.02 - HA 1 TA 0 - 16.0.21.0
Device bus : <> HA 1
Host system bus : <S-ATA>
Drive buffer : 4064kB
Bus Type : via Inquiry data
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD/DVD-ROM : <HL-DT-ST BD-RE WH14NS40 > FW version: 1.02 - HA 1 TA 0 - 16.0.21.0
=== Scsi-Device-Map ===
: WDC WD3200AAJS-60Z0A03.0 storahci Port 2 ID 0 DMA: Off
: HL-DT-STBD-RE WH14NS40 1.02 storahci Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST BD-RE WH14NS40 D: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use : 23 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
8.5.2020
UDF compilation
23:38:41 #1 Text 0 File SCSIPTICommands.cpp, Line 617
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
23:38:44 #2 Text 0 File Isodoc.cpp, Line 7684
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
23:38:44 #3 PHASE 214 File dlgbrnst.cpp, Line 2095
Generation of disc structures started
23:38:44 #4 Text 0 File compose.cpp, Line 970
GenUDF2: 1 transfer items prepared.
23:38:44 #5 PHASE 215 File dlgbrnst.cpp, Line 2095
Generation of disc structures completed
23:38:44 #6 Text 0 File Burncd.cpp, Line 3837
Turn on Disc-At-Once, using Blu-ray Disc media
23:38:44 #7 Text 0 File DlgWaitCD.cpp, Line 335
[D: BD-RE WH14NS40 ] Total disc capacity: 12219392 23866MB
User data to be written: 11669920 22792MB
Free space on disc: 12219392 23866MB
23:38:44 #8 Text 0 File DlgWaitCD.cpp, Line 347
[D: BD-RE WH14NS40 ] Write in overburning mode: NO (enabled: CD)
23:38:44 #9 Text 0 File DlgWaitCD.cpp, Line 3129
Recorder: HL-DT-ST BD-RE WH14NS40, Media type: BD-R (seq)
23:38:44 #10 Text 0 File DlgWaitCD.cpp, Line 537
[D: BD-RE WH14NS40 ] >>> Protocol of DlgWaitCD activities: <<<
23:38:44 #11 Text 0 File ThreadedTransferInterface.cpp, Line 879
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 11669920 (11669920) = #11669920/2593:18.70
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 11669920 blocks [D: HL-DT-ST BD-RE WH14NS40]
23:38:44 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1095
Prepare [D: HL-DT-ST BD-RE WH14NS40] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 23899996160, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 11669920 | 0 | 0x00
11669920 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
MediaType: BD-R
23:38:44 #13 Text 0 File SCSIPTICommands.cpp, Line 404
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
23:38:44 #14 Text 0 File Burncd.cpp, Line 4735
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
23:38:44 #15 PHASE 24 File dlgbrnst.cpp, Line 2095
Caching of files started
23:38:44 #16 Text 0 File Burncd.cpp, Line 4857
Cache writing successful.
23:38:44 #17 PHASE 25 File dlgbrnst.cpp, Line 2095
Caching of files completed
23:38:44 #18 PHASE 36 File dlgbrnst.cpp, Line 2095
Burn process started at 8x (35,960 KB/s)
23:38:44 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2926
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
23:38:44 #20 Text 0 File Cdrdrv.cpp, Line 10845
---- Disc Structure (BD): Disc Information on BD (00h) ----
Media Type: 1, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 4098
--- Header ---
Disc Information Identifier: <DI>
Disc Information Format: 01 h
Number of DI Units/Aux Frames in each DI block: 5
Number of (recording) layer to which this DI Unit applies: 0
DI unit Sequence Number in DI Block: 0
Continuation flag: Next DI Unit is the start of a new set of parameters (0)
Number of DI bytes in use in this DI unit: 98
--- Body ---
Disc Type Identifier: <BDR>
Disc Size/Class/Version: 1
DI Unit Format dependent contents:
BD Structure: 18 (12 h):
1 recording layer (SL), BD-R
Hybrid Disc identifier/Channel bit length: 1 (1 h):
no DVD layer present, no CD layer present
channel bit length of 74,5 nm (25.0 GB max. per layer)
Push-Pull polarity flag bits: 00 h
Recorded mark polarity flag bits: 00 h
BCA descriptor: BCA-code present (1)
Maximum transfer rate needed by the application: 0 Mbit/s
Data zone allocation:
First Physical ADIP Address of the Data Zone of the related layer (FAA): 00020000 h (131072)
Last Physical ADIP Address of the Data Zone of the related layer (LAA): 00194E7E h (1658494)
Recording velocities:
Nominal Recording Velocity: 4.92 m/s (1EC h)
Maximum Recording Velocity: 4.92 m/s (64 h -> 100/100)=1
Minimum Recording Velocity: 4.92 m/s (64 h -> 100/100)=1
12 01 00 00 01 00 00 00 - 00 00 00 00 00 02 00 00
00 19 4E 7E 01 EC 64 64 - 28 28 28 28 1E 1E 1E 1E
00 00 00 00 63 66 72 04 - 04 32 1E 96 80 00 00 00
00 08 08 08 08 10 10 10 - 10 48 00 48 00 48 00 48
00 48 00 48 00 48 00 48 - 00 48 00 48 00 48 00 48
00 80 80 A0 C0 E0 00 00
--- Trailer ---
Disc Manufacturer ID: 56 45 52 42 41 54 h <VERBAT>
Media Type ID: 49 4D 65 <IMe>
Time Stamp [m:y]: 3 : 2010 (7D A3 h)
Product Revision Number: 0
23:38:44 #21 SPTI -1066 File SCSIPassThrough.cpp, Line 225
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x0cc27800: Len x648
23:38:44 #22 Text 0 File BD.cpp, Line 416
Allocated spare area size on disc 620000h
BD: Start write address at LBA 0, Recording mode: unknown Recording Mode (0),
spare area allocation: default (no action) (0), Stream recording: NO (0); return code 0
23:38:44 #23 Text 0 File ThreadedTransfer.cpp, Line 275
Pipe memory size 83836800
23:38:44 #24 Text 0 File CUDFTransferItem2.cpp, Line 713
GenUDF2 FS Layout:
Sectors to be written: 11669920
Session Start: Sector 0
Volume Structure: Sector [0, 256] (257 Sectors)
Meta Data: Sector [257, 322] (66 Sectors)
Data: Sector [323, 11669595] (11669273 Sectors)
After Data: Sector [11669596, 11669599] (4 Sectors)
Trailer Track: Sector [11669600, 11669919] (320 Sectors)
GenUDF2 Parameters:
PrepTime: 05-08-2020 23:38:44
UDF Revision: 1.02
UDF Partition Type: Physical
UDF Special Mode: None
Bytes per Sector: 2048
Session Start: 0
Physical Partition Start: -1
Total Capacity: 12219392
Multi Session Mode: None
Disc Type: BD-R
OS Class: 0
Volume ID: My Disc
Allow Unicode Labels: 0
Duplicate Meta Data: 1
MS Info File: 00000000
VMS Rollback File: 00000000
Create ISO bridge: 0
ECC Block Length: 32
Sparing Packet Length: 32
Allocation Unit Size: 32
Alignment Unit Size: 32
Make Writable: 0
Access Type: Read-only
23:39:01 #25 SPTI -1135 File SCSIPassThrough.cpp, Line 225
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x104c1040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
23:39:01 #26 TRANSFER -20 File ThreadedTransfer.cpp, Line 1235
Could not perform Write
23:39:01 #27 CDR -1135 File Writer.cpp, Line 345
Write error
23:39:21 #28 Text 0 File DVDPlusDualLayer.cpp, Line 1464
SetDriveCaps: Set LAST LBA of layer 1 to 0
23:39:21 #29 PHASE 38 File dlgbrnst.cpp, Line 2095
Burn process failed at 8x (35,960 KB/s)
23:39:21 #30 Text 0 File SCSIPTICommands.cpp, Line 454
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
23:39:21 #31 Text 0 File Cdrdrv.cpp, Line 12297
DriveLocker: UnLockVolume completed
23:39:21 #32 Text 0 File SCSIPTICommands.cpp, Line 617
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Results 1 to 13 of 13
I think I have the same drive as you. I normally have to clean it out once a year or every other year. Recently did it with compressed air (sprayed randomly inside) and then had it verify a few discs at full speed to try and use air to clean the lens. Worked fine after that.
I also burn everything at 4x, as any higher I get more bad discs. -
JUST TRIED WITH IMGBURN
It seemed to be ok, up to the verify point ,but failed again - the BD-R disc appears to be blank in windows explorer
Windows 8 6.2
AMD64
Wow64Process
(Nero Express)
AutoRun : 1
Excluded drive IDs:
BUFE : 0
8.5.2020
UDF compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Revision : 1.02
DAO infos:
MCN: ""
DAO layout:
MediaType: BD-R
--- Header ---
--- Body ---
--- Trailer ---
Sense Code: 0x24
Sense Qual: 0x00
GenUDF2 FS Layout:
GenUDF2 Parameters:
UDF Revision: 1.02
Session Start: 0
Disc Type: BD-R
OS Class: 0
Volume ID: My Disc
Make Writable: 0
Sense Code: 0x0C
Sense Qual: 0x00
Write error
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL -
try uninstalling your LG blu ray writer, restart your computer
and let windows reinstall the drive and then try burning your disc again. -
There is nothing intrinsically wrong with Verbatim BD-R HTL media, as far as I know. I can't recall ever having one of them fail verification.
Verbatim BD-R LTH media has more problems. Some early Blu-ray burners could not ever successfully burn Verbatim BD-R LTH media, although your burner is not old enough to be one of them.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
It isn't unusual for a dirty or failing drive to work better with one brand or type of a particular media than another. Different brands and types can use different write strategies.
Verbatim actually makes 3 different types of BD-R media, HTL, LTH, and M-DISC, which I forgot to mention. Some Blu-ray drives don't work with M-DISC media, but yours has M-DISC support. However, M-DISC is supposed to require more power when burning and is rumored to wear out the laser more quickly.
Verbatim LTH BD-R discs have "LTH" somewhere on the package label. They were created as a less expensive option and use an organic dye for the recordable layer. M-DISC media has "M-DISC" somewhere on the package and uses a proprietary inorganic material for its recording layer. "HTL" denotes the regular Verbatim BD-R ("HTL" is not found on the label) and uses a metallic alloy for its recordable layer.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Wasn't the Verbatim brand recently sold off to a new company? https://www.cdrom2go.com/blog/mitsubishis-disc-company-verbatim-sold-to-cmc
LOL wasn't recent but cmc is the owner of the verbatim brand name now. it can be on any cmc discs produced anywhere now.
CMC also owns and manufactures Taiyo-Yuden discs (which hasn't existed as a separate entity since 2015) discs. https://forum.videohelp.com/threads/389210-CMC-manufacturing-Taiyo-Yuden-DVDs
The key with both Verbatim and Taiyo Yuden is that CMC (for now) uses the original formulas and adheres to the manufacturing and QC specifications. -
Yep. Don't know about Blu-Ray discs, but even Verbatim pre-buyout was playing games with their DVD packaging https://forum.videohelp.com/threads/391272-Beware-of-new-Verbatim-non-AZO-packaging
Blu Ray blank disc issue - disc or writer?
By Damirko1981 in forum MediaReplies: 1Last Post: 10th Oct 2019, 13:44 -
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 01:11 -
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 07:32 -
Verbatim 25 GB Blu Ray Not working :(
By amitabhbansal in forum MediaReplies: 6Last Post: 18th Aug 2016, 22:38 -
By amitabhbansal in forum MediaReplies: 7Last Post: 2nd Jun 2016, 14:11
