  1. I usually stay away from that kind of footage but here i go.
    The file is 1080p but was most likely 480i originally
    sample here:
    https://mega.nz/file/81IRBS4a#nGkvuV3h99x4MbAyDv6SYFtq2rQ3RWegGMcN3tMN_To
    avisynth script welcomed (or better i'm open)
    Thanks for your help
    edit:
    Well so far i came up with this:
    LWLibavVideoSource(source="video.MOV")
    SeparateFields()
    e=SelectEven().Yadif(mode=0, order=-1, planar=false, opt=-1)
    o=SelectOdd().Yadif(mode=0, order=-1, planar=false, opt=-1)
    Interleave(e,o)
    Weave()
    return last.spline36resize(720,480) # (the resizing works best at the end, not before it seems)
    Johnmeyer has coded a script specifically for this it seems, but i can't make it work right
    Source: https://forum.doom9.org/showthread.php?p=1685187#post1685187
  2. I don't see any evidence of the "resize interlaced video without first deinterlacing" problems that I dealt with in that thread. Actually, I don't see too much wrong with your clip, other than the total lack of any detail.
  3. Uhg, that's some ugly source. Here's what I came up with:
    # build a mask of areas where there are
    # alternating horizontal lines
    function AltHzLineMask(clip v)
        Subtract(v, v.blur(0.0, 1.0).Sharpen(0.0, 0.6))
        GeneralConvolution(0, "
            0  8  8  8  0
           -0 -8 -8 -8 -0
            0  8  8  8  0
           -0 -8 -8 -8 -0
            0  8  8  8  0", chroma=false, alpha=false)
        mt_lut("x 125 - abs")
        mt_binarize(6) # threshold, adjust to source
        mt_inpand()
        mt_expand()
        mt_expand(chroma="-128")
    LSmashVideoSource("2Pac_Snoop-sample.mp4")
    src = last
    # build a mask of areas where there is combing
    ConvertToYV24() # convert to YV24 so we can specify an odd height
    Spline36Resize(width,431) # found experimentally
    AltHzLineMask()
    mask = Blur(1.0).BilinearResize(src.width, src.height).ConvertToYV12()
    # blur the comb artifacts by downscaling, then upscaling
    src
    Spline36Resize(width, 240)
    Spline36Resize(width,1080)
    # overlay the blurred image only where there are comb artifacts
    Overlay(src, last, mask=mask)
    # show before, after, mask
    #Interleave(src, last, mask)
    You'll get blending where there used to be comb artifacts. The video is too far gone for something like FixBlendIVTC() to repair it after this.
  4. I'm tryin' your script with avisynth 2.6 MT jagabo: error "general convolution does not have a named argument chroma"
  5. I'm using AviSynth+. 2,6 GeneralConvolusion only works with RGB32 Remove the chroma and alpha arguments. And ConvertToRGB32() before calling it, then ConvertToYV24() after.
        ConvertToRGB32()
            0  8  8  8  0
           -0 -8 -8 -8 -0
            0  8  8  8  0
           -0 -8 -8 -8 -0
            0  8  8  8  0")
        ConvertToYV24()
        mt_inpand()
        mt_expand()
  6. thanks jagabo, i like your script, that plus qtgmc("slower",inputtype=1) right after works best imo. I don't think i can expect much better i'll stop bangin my head for now.
