Hi, I want to record a DV video. I tried DScaler but the scheduled recording mode doesn't work. Also there's no video at all on VirtualDub or WinDV. Any ideas?
Results 1 to 9 of 9
Are you using some kind of an analog-to-digital or analog-to-DV capture device? If so, which one?
For what it is worth, I don't recall seeing any capture software that could be set up to start and stop recording on a time-based schedule. The only kind of timed-recording software that I have ever found is PVR/DVR software, which is intended to be used with PC TV tuner devices. There were a few capture devices made by Hauppauge that could do timer-based recordings using certain PVR software. These few devices worked because they could impersonate a digital TV tuner after installing a special plug-in. However, none of them could capture in DV. All of them captured in H.264 via an onboard encoding chip and output a TS stream, similar to a digital TV tuner.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I'm using an analog to digital usb thing. https://www.amazon.fr/gp/product/B00TFNP4BS/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
I don't need a scheduled start, I just want to start recording manually and define a recording length. -
did you try looking in the screen capture / screen recording software section ?? - https://www.videohelp.com/software/sections/desktop-screen-capture
You could use the windows scheduler to start a batch script. In this script you could start virtualdub from the command line to do the DV recording.
Free screen recording software compatible with XP?
By Rekrul in forum Newbie / General discussionsReplies: 6Last Post: 17th Nov 2019, 18:42 -
Software setup that does loop recording / continuous recording.
By ruant in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2018, 05:41 -
tv shows scheduled to air listing
By vhelp in forum Off topicReplies: 1Last Post: 16th Dec 2015, 19:24 -
searching software to know codec video/audio
By H265 in forum Software PlayingReplies: 7Last Post: 11th Sep 2015, 12:49 -
which recording software is this?
By 1Ganger in forum ComputerReplies: 1Last Post: 23rd Aug 2015, 05:19
