Analog capture will pretty much always be top field first, so presumably that's the case here too. The exception being stuff that capture directly to the DV format like the AVDC devices or Digital8 camcorders.
With e.g Virtualdub you can load up the video, and add a deinterlacing filter manually. If you select a deinterlacing filter that doubles framerate, it's quite noticeable if the field order is wrong as the video will stutter. -
if you have enough drive space, you can also capture lossless with virtualdub using huffyuv codec. you can deinterlace later. so you always have a high quality capture
Elgato Video Capture vs. Hauppauge 610 USB-Live 2 - Raw Comparison
By CZbwoi in forum Capturing and VCRReplies: 40Last Post: 6th Dec 2022, 14:40 -
USB LIVE 2 Hauppauge - TV recorded video freezes all others ok
By Ingallspw in forum Capturing and VCRReplies: 5Last Post: 27th Oct 2018, 11:27 -
How to know if cutting on a top or bottom field?
By SameSelf in forum EditingReplies: 3Last Post: 9th Aug 2017, 17:34 -
Strange file, doesn't play on PC, fine on USB player, wrong field order?
By Killer3737 in forum Newbie / General discussionsReplies: 9Last Post: 1st Mar 2016, 19:14 -
Hauppauge : USB-Live2 (Green bar at bottom, 20% of the screen!!!)
By Keitaro004 in forum Capturing and VCRReplies: 24Last Post: 7th Dec 2015, 00:43
