This happens when there is a lot of motion in the video.
[Attachment 53178 - Click to enlarge]
This is the same VHS tape but with no motion:
[Attachment 53179 - Click to enlarge]
	How did you watch it? Did you preprocess (resize, re-encode) the VHS source?
 There is probably nothing wrong with your original VHS source. It is just interlaced. You should switch the deinterlacer (or bobber) ON in your player for viewing. Check its settings.
 The first picture shows the interlaced combing when you watch it downscaled without applying a deinterlacer (or bobber). In the second picture you don't see the combes because there is no motion between the 2 fields of the interlaced video.
 You can find more on this here:
 http://www.100fps.com/
 When you watch the VHS tapes on TV it should look ok, because the TV (or HW player) will normally automatically deinterlace (or bob) it.
 If it doesn't your video has possibly been resized (and reencoded) without prior deinterlacing. Then the damage is there and there is no easy fix.
 Upload a sample (few seconds, with motion scene) of your source for better help.Last edited by Sharc; 8th May 2020 at 04:26. Reason: added URL
  How do you reduce color noise in Staxrip?By SomeoneNeutral in forum RestorationReplies: 6Last Post: 31st Aug 2019, 12:47
  VSDC trying to reduce noise from camera in audioBy JytteC in forum Newbie / General discussionsReplies: 4Last Post: 19th Apr 2019, 17:03
  How to reduce the graininess?By bebetoalves in forum Video ConversionReplies: 1Last Post: 27th Mar 2017, 14:36
  Reduce video bitrareBy fits79 in forum Video ConversionReplies: 2Last Post: 20th Feb 2016, 00:04
  ffmpeg noise filter usage based on mplayer noise settings?By Selur in forum Video ConversionReplies: 5Last Post: 21st Jun 2015, 09:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
