I am creating my own DVD discs with only one hour of video on each. If I have room on the disc for LPCM audio is it better to use than Dolby Digital? What are the advantages/disadvantages to using these two formats baring in mind I can fit LPCM on my disc?
For stereo soundtracks, DD has no real advantages over PCM other than size, at least as far as I can see. Also, many consumer level DVD authoring programs will not handle DD encoded audio, so it may not even be a choice depending on the authoring packages you have available. If you can produce 5.1 channel audio somehow, and author it, DD is the way to go.
Actually, I have used DVDit PE with dolby digital and had strange sync problems on some movies. So for this reason alone I would stick with PCM if you can. Personally I cant see any advantage to using DD other than file size.
Funny you should say that. I too have had sync problems with DVDit! PE. What do use use now?
If I can get away with it sound/size wise I use MyDvd, also by sonic, but does not support DD. I suppose DVDitPE with PCM would also work. As I dont always get sync probs, if the movie is too big for PCM audio to be used I try DVDitPE but author to HD 1st to test. If I still have a problem with sync I usually end up re-encoding at a lower bitrate to allow me to use PCM! Not Ideal I know but have not yet splashed out on any alternatives as, reading these forums, they all have problems of one sort or another!
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
Dolby Digital 5.1 Output
By skorpinok in forum AudioReplies: 1Last Post: 25th Aug 2010, 12:31 -
Dolby Digital 5.1-ch vs. Dolby Digital 2-ch
By coody in forum DVD RippingReplies: 6Last Post: 21st Jun 2008, 15:35 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54
