I recorded an old baseball radio broadcast on my computer last night using Audacity and wondering what settings I should use to export the file to mp3. IT first asks for bit rate mode (preset, variable, average, constant. I know the quality refers to the amount of compression and higher kbps is less compressed.
I also have a choice for variable speed (fast or standard) and Channel mode (joint stereo, stereo or force export to mono.
Thanks!
As most radio broadcasts of baseball, especially old ones, are mono, choose Mono.
This is speech with some minor fx and bkgd music added (usually poor quality reproduction), so I would say 128kbps would be more than sufficient, probably 96, or 64, or maybe even 48 or 32. Doesn't hurt to leave it in better quality, and would certainly have less issues.
Go w standard speed.
Variable is more efficient, so would save on filesize, but some older players might have issue w it, so I would go w constant.
Dithering Settings in Audacity
By Dabuss55 in forum AudioReplies: 4Last Post: 22nd Jun 2019, 05:52 -
Audacity help
By loa909 in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2018, 12:34 -
Exporting MP4 to MP3 From VLC Player Shortens Timeline?
By pone44 in forum AudioReplies: 3Last Post: 5th Feb 2017, 11:39 -
Audacity does not start
By cornemuse in forum AudioReplies: 4Last Post: 27th Sep 2015, 10:09 -
best quality settings for exporting video
By efc1978 in forum Video ConversionReplies: 23Last Post: 10th Jun 2015, 22:21
