Hi!
I am trying to record some VHS tapes. I have one of those easycaps and have been using the app USB camera on my oneplus 7 pro. I had a bunch of driver issues when trying on windows ( no sound ) . As you can see in the picture it seems that the horizontal lines aren't aligning correctly, could this be some format issue I'm having? I tried with the different PAL and NTSC formats available. Or is it likely the easycap or the app I'm using that is the issue? The app seems to have a wide range of settings.
image: https://imgur.com/a/8bKlHhw
Thanks for any help!
Camcorders usually shoot interlaced video. Each frame contains two half pictures, one in all the even scanlines, one in all the odd scanlines. You need to encode the video interlaced so that the player knows to detinterlace on playback. Or you need to deinterlace (turn each half picture into a full picture) and encode progressive.
Anyone know of a sub program that will break long lines into 3 lines?
By JeremyBrown in forum SubtitleReplies: 19Last Post: 13th Apr 2020, 19:03 -
Removing noisy lines in VHS captured DV video, perhaps with Atom Inspector
By celsoac in forum EditingReplies: 0Last Post: 27th Apr 2019, 08:55 -
Virtualdub captured video has full horizontal lines when played on VLC
By zymok in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2017, 09:04 -
Lines on video during capturing and on captured video.
By nusratjaveid in forum Capturing and VCRReplies: 6Last Post: 17th Mar 2016, 14:13 -
Green lines on captured video file
By nusratjaveid in forum Capturing and VCRReplies: 6Last Post: 20th May 2015, 14:08
