Hi! My brother spent many hours noting time stamps in a 17+ hour mp3 file. Unfortunately, he used vlc instead of a DAW, so the timestamps are all estimates that vlc understandably made. Thus they don't correlate in a DAW when it comes to actually using the time stamps for editing.
I was wondering if there was a clever way anyone knew to "correct" these values, if given an list. I expect you would have to know the vlc estimation algorithm (maybe it's well-known? or maybe vlc could be scripted somehow to leverage it?), go to the estimated time stamp location, save a snippet of decoded audio, then use a second program to scan through the whole file, decoding as you went and trying to match the saved snippet. Seems like this amount of effort is not worth it, but I thought I'd check here in case anyone had some clever scripting ideas... for all I know ffmpeg has a command line option to do exactly this, or maybe someone has written this utility already?
Thanks!
Results 1 to 1 of 1
(subtitle edit) About "merge lines with same timecode"
By heisiheisi in forum SubtitleReplies: 5Last Post: 12th Oct 2020, 15:48 -
VLC "X" algorithm deinterlacer export
By Hamsword in forum RestorationReplies: 6Last Post: 16th Oct 2018, 09:32 -
How the "see" correct BT.709 color using VLC in a PC?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 25th Jun 2017, 10:57 -
[SOLVED] Adjust "timecode" rate to 24
By Rafael Linux User in forum Video Streaming DownloadingReplies: 8Last Post: 17th May 2017, 06:11 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21
