Hi, I would like to smooth and denoise this scene. This is what I tried so far:
- Capture using an S-Video cable on an S-VHS (HR-S8600EU) with Grabster AV 350 MX. Unfortunately it captures natively in mpeg2 with Magix software (I tried Virtual Dub but the frames were all messed up);
- Encoding of a shorter avi in Lagarith with Virtual Dub;
- Filtering in Avisynth, second Lagarith avi encoding.
I modified the scripts in this threadCode:LWLibavVideoSource("...Intermediate.avi", format="YUV420P8") Stab(dxmax=0, dymax=2) function YMask(clip v, int min, int max) { Levels(v, min, 1, max, 0, 255, coring=false).GreyScale() } original = last mymask = original.YMask(15,35) denoised = original.MCTemporalDenoise(settings="medium", chroma=true, stabilize=true) Overlay(original, denoised, mask=mymask) RemoveGrain(5).RemoveGrain(5)
https://forum.videohelp.com/threads/393934-McTmporalDenoise-function-question
but I feel I am not making the best use of them, denoising is incomplete. Any help would be appreciated.
I tried the method suggested in this post http://forum.doom9.org/showthread.php?p=1493091#post1493091
I tried to add ColorYUV(source, gain_y=-50, gamma_y=50, off_y=-2) but nothing changed. Should I change luma and add smoothing?Code:source=LWLibavVideoSource(".....Intermediate.avi", format="YUV420P8") #VHS chroma settings can sometimes cause smear. Skip CNR2 if not needed. chroma=source.Cnr2("oxx",8,16,191,100,255,32,255,false) #VHS #chroma=source.Cnr2("oxx",8,14,191,75,255,20,255,false) #Laserdisc #Use 4 instead of 8 in line below for better quality in shadows output=MDegrain2i2(chroma,4,0,0) #stackhorizontal(source,output) return output #------------------------------- function MDegrain2i2(clip source, int "blksize", int "overlap", int "dct") { Vshift=0 # 2 lines per bobbed-field per tape generation (PAL); original=2; copy=4 etc Hshift=0 # determine experimentally overlap=default(overlap,0) # overlap value (0 to 4 for blksize=8) dct=default(dct,0) # use dct=1 for clip with light flicker -- works really well fields=source.SeparateFields() # separate by fields super = fields.MSuper(pel=2, sharp=1) backward_vec2 = super.MAnalyse(isb = true, delta = 2, blksize=blksize, overlap=overlap, dct=dct) forward_vec2 = super.MAnalyse(isb = false, delta = 2, blksize=blksize, overlap=overlap, dct=dct) backward_vec4 = super.MAnalyse(isb = true, delta = 4, blksize=blksize, overlap=overlap, dct=dct) forward_vec4 = super.MAnalyse(isb = false, delta = 4, blksize=blksize, overlap=overlap, dct=dct) MDegrain2(fields,super, backward_vec2,forward_vec2,backward_vec4,forward_vec4,thSAD=400) unsharpmask(60,3,0) #not sure whether to put this before or after the weave. Remove if sharpening degrades video Weave() }
AI Interpolation of NASA footage (Smoothing/Increasing Fps)
By Dutchsteammachine in forum Newbie / General discussionsReplies: 33Last Post: 19th Jul 2020, 15:19 -
Fading JPEGs
By oofers in forum Newbie / General discussionsReplies: 9Last Post: 6th Apr 2019, 22:09 -
SmoothHiQ ddl Diameter=13 Spatial Smoothing, eliminate noise MPEG artifacts
By Tom4 in forum EditingReplies: 18Last Post: 8th Nov 2017, 23:54 -
Fading Between Scenes
By ab-tools in forum Newbie / General discussionsReplies: 10Last Post: 6th Jul 2017, 16:03 -
Avisynth, help with scene by scene cropping
By KarMa in forum Video ConversionReplies: 4Last Post: 26th Nov 2015, 10:00
