Results 1 to 17 of 17
    Nov 2019
    Sopron
    Hello!
    The Holy Grail Settings of NVENC HEVC, Can you find better general preset for low bitrate (2500 Kbit/s) video?
    If you found, please share it!
    I used the latest Hybrid , Rigaya's NVENC with the following presets:
    NVEnc --avhw -i -INPUT- --fps 23.976 --codec h265 --profile main10 --level 6.2 --tier high --sar 1:1 --lookahead 32 --output-depth 10 --vbrhq 2500 --max-bitrate 240000 --gop-len 600 --strict-gop --ref 7 --multiref-l0 7 --multiref-l1 7 --nonrefp --bframes 1 --bref-mode disabled --no-b-adapt --mv-precision Q-pel --cu-max 32 --cu-min 8 --preset quality --colormatrix bt709 --vpp-resize default --output-res 1920x1080 --vpp-gauss disabled --cuda-schedule auto --keyfile GENERATED_KEY_FILE --psnr --ssim --output "C:\Users\007\AppData\Local\Temp\2 b solid.265"
    I also used Rigaya's built-in PSNR and SSIM measurement tool too.
    Nov 2019
    Sopron
    Any idea?
  3. --bframes 1 --bref-mode disabled
    have you tried enabling bref-mode and using more b-frames?
    Nov 2019
    Sopron
    I made 1b frame 2 b frame and 3b frame encodings, with two variations: 1 / with adaptive B-frame 2/ with fixed (solid) b frames.
    I uploaded here the results:
    https://sendgb.com/M0YSreEQlWX
    Here is the original source file: https://sendgb.com/8pCny1KD76d
    Is the fixed (solid) 1B frames the best version?
    Nov 2019
    Sopron
    SOLID (FIXED) 1 B frame results:
    SSIM YUV: 0.959519 (13.927510), 0.987063 (18.881730), 0.987414 (19.001062), All: 0.968759 (15.052747), (Frames: 4922)
    PSNR YUV: 41.852698, 47.663324, 47.616219, Avg: 43.075502, (Frames: 4922)
    __________________________________________________ __________________
    Adaptive 1 B frame results:
    SSIM YUV: 0.959268 (13.900629), 0.987143 (18.908510), 0.987484 (19.025379), All: 0.968616 (15.032970), (Frames: 4922)
    PSNR YUV: 41.782242, 47.695861, 47.645941, Avg: 43.016762, (Frames: 4922)
    __________________________________________________ _______________________
    SOLID 2 B frame results
    SSIM YUV: 0.959184 (13.891746), 0.987477 (19.022821), 0.987908 (19.174925), All: 0.968687 (15.042762), (Frames: 4922)
    PSNR YUV: 41.775293, 47.845018, 47.824288, Avg: 43.028969, (Frames: 4922)
    __________________________________________________ _________________________________
    Adaptive 2B frame results:
    __________________________________________________ _____________________________________
    Solid 3B frame results:
    SSIM YUV: 0.958440 (13.813271), 0.987824 (19.144857), 0.988285 (19.312587), All: 0.968312 (14.991001), (Frames: 4922)
    PSNR YUV: 41.629757, 47.991645, 47.985072, Avg: 42.915426, (Frames: 4922)
    Adaptive 3 b frame results:
    SSIM YUV: 0.958726 (13.843203), 0.987423 (19.004305), 0.987791 (19.133101), All: 0.968353 (14.996646), (Frames: 4922)
    PSNR YUV: 41.657191, 47.811351, 47.769798, Avg: 42.918961, (Frames: 4922)
    Dec 2012
    Germany
    make it preset slow
    Nov 2019
    Sopron
    Originally Posted by Zero-11 View Post
    make it preset slow
    Is it possible in Rigaya's version of NVENC for the "preset slow" ?
    Here is Rigaya's NVENC option list: https://github.com/rigaya/NVEnc/blob/master/NVEncC_Options.en.md
  8. Have you actually looked at the streams? Do not trust the metric, trust your eyes.
    Nov 2019
    Sopron
    Hello Selur!
    Which video is the best according to your visual test?
  10. doesn't matter, quality is in the eye of the beholder
    Nov 2019
    Sopron
    Yes, but you have also eyes, thus you have also an opinion...
    Dec 2012
    Germany
    make it preset slow
    it says you are using b-frames which indicates a Turing card, fast/medium/slow are the new Turing settings which have better quality
    if Rigaya's version doesn't support it try Handbrake
    Nov 2019
    Sopron
    make it preset slow
    But it uses FFMPEG, which is infamous from its bad quality and slow encoding speed among the HW encoders. FFMPEG has not even proper HW decoder for input videos. In FFMPEG, everything goes trough the system memory and CPU, which makes the process backward/outdated.
  14. Handbrake, FFmpeg and NVEncC usually all use the same libraries (from the current NVIDIA SDK) to access the VPU on your graphic card, so unless someone messes up, the quality should not differ.
    It's just a difference how NVEncC and Handbrake name an option (and if they offer it to the user).
    In case of the presets, Handbrake offers presets named 'fast/medium/slow' while NVEncC names them "performance/default/quality".
    Cu Selur
    Dec 2012
    Germany
    Cu Selur
    yea right. that's why the 1st ones have better quality, Handbrake didn't name them different. it has all of them
    Nov 2019
    Sopron
    Cu Selur
    But Handbrake uses only FFMPEG, and FFMPEG has very few options for HW encoders.
  17. Handbrake does not use FFmpeg.
    It uses libav and other libraries and since libav is originated in FFmpeg sometimes folks write Handbrake uses FFmpeg, which it does not.
    Like I wrote before both FFmpeg, Handbrake and NVEncC all use the same libaries, it's just a question of which option they support and how.
    Cu Selur
