  1. Member DanilaZabiaka's Avatar
    May 2020
    Чебоксары
    Hey from Russia, friend. Im fan of potplayer and created my own bulid to give my favorite player some features
    I ported SVP (smooth video project) to PotPlayer's avisynth i called it Uplavnyalka
    Added some great shaders like debanding (removes blocks of video), black/white level control, my skin can hide time bar and have a lot of things
    Out of box, my build has russian language
    U can donwload it
    pxsahders https://www.upload.ee/files/11303646/PxShader.7z.html
    avisynth scripts https://www.upload.ee/files/11246768/AviSynth.7z.html
    I answer for my build with my face 8)
  2. Member DanilaZabiaka's Avatar
    May 2020
    Чебоксары
    btw my SVP port is like free, faster/better version than original svp
    svp works with unoptimized old ffdshow, which is buildin in potplayer by dev. Also, potplayer has faster resize algorithm, it gives advantages when you watch 1080p on x768 display
    Difference with/without my pxshaders (some of them after jpg compression, but they are scaled) for youtube video
  3. Hi @DanilaZabiaka! I would like to try this project of yours. But I don't know if I'm doing it right.
    What I have done so far:
    1. Opened potplayer and gone to settings.
    2. I go to Video>>AviSynth
    3. Under AviSynth, I clicked Load script>>Load script from a file and selected "Uplavnyalka35-CPU.avs"
    4. I checked "Enable AviSynth processing" clicked "Apply" and "OK".
    [Attachment 55516 - Click to enlarge]
    I tried playing a video but it shows me this:
    [Attachment 55515 - Click to enlarge]
  4. Hoping for your reply.
  5. Member DanilaZabiaka's Avatar
    May 2020
    Чебоксары
    Hey! Previous file looks damaged, there is reupload
    https://drive.google.com/file/d/1OiWn2MVSBAJt15OZCSpqnO46jQ3q8N1R/view?usp=sharing
    PotPlayer should be x64. If there is something wrong, PP writes yellow text in the top of the video...
  6. Thank you for responding @DanilaZabiaka!
    What should I do with the PxShader and msvcp140.dll? Where should I put them?
    Also, does PxShader needs to be configured just to be used, or I just only need to paste it to the right place and it will automatically work? Thank you again!
