Hi, I've been transferring VHS tapes to PC using A/V composite to Canopus 100 then 6pin firewire output into my older laptop with a 4pin firewire input and capturing using Windv.
I have a Canon zr90 minidv camcorder I want to transfer tapes from. It has a 4pin firewire port. Can I transfer directly from the camcorder to the PC (then capture with windv) using a 4pin to 4pin cable or will I have to use the Canopus? If I have to use the Canopus, would I also use 4pin to 4pin, then the same 6pin to 4pin cable to connect to the PC?
4pin to 4pin cables don't seem as readily available as 6pin to 4pin, so I want to make sure I'm thinking this correctly before buying one. Also, is it better to get a shorter cable or does length not matter as far as data/picture quality?
Yes you can use 4pin<-->4pin. The 2 extra pins supply power to devices, but if you are using a separate power supply anyway (you should), it won't matter. Treat them as identical performancewise and use whatever combo gets you connected.
Length under the max allowable won't matter much either.
Scott -
almost all dv cams have 4 pin ports. not sure what the problem is? 4pin to 6pin input on computers is the normal work flow.
Ground in audio/video cables
By Mark22 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2017, 11:24 -
what's the difference with these composite/s-video cables?
By Knightmessenger in forum Capturing and VCRReplies: 3Last Post: 4th Oct 2016, 18:49 -
9 pin din cables
By coldplayfan in forum Newbie / General discussionsReplies: 7Last Post: 19th Apr 2016, 07:46 -
No Firewire Port? Apple Thunderbolt to FireWire Adapter MD464LL/A
By techiejustin in forum Capturing and VCRReplies: 0Last Post: 16th Feb 2016, 17:08 -
dvi cables and their pins
By ricmetal in forum ComputerReplies: 5Last Post: 30th Jul 2015, 14:53
