Try DVDFab and copy Ultra HD Blu-rays and DVDs! Or rip iTunes movies and music! Download free trial !
Results 1 to 17 of 17
  1. So I have recently purchased a used xha1 the camera seems to be fully functional it records and plays back just fine, although for the life of me I cant get it to connect to my older mac mini running yosemite 10.10.5. I have an older sony high 8 dv cam that connects and sends dv signal no problem to the mac mini. I'm wondering if I'm getting something wrong on the xha1 DV out settings? Or maybe the cameras dv feature is broken? I'm kinda lost and any help would be great.
    Thanks in advance.
  2. When I go try and download the driver the canon page tells me there is no driver for yosemite 10.10
    Feb 2006
    try contacting their support
  4. I tried calling yesterday when you tell them the product name they say that they no longer have phone support for that camera since itís discontinued.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    dv/hdv doesn't require a camera specific driver. it's all included in the os as they all use the same signals over firewire.
  6. Thatís my whole issue itís not connecting to a os thatís claims it doesnít need a driver but the camera wonít connect Iíve tried iMovie, QuickTime and the computer refuses to see the canon. As mention earlier I have a Sony dv cam that connects just fine. So Iím wondering if there are any xha1 owners who can specifically help me out because Iíve done all the general ideas here nothing is working.
    Feb 2006
    here's the manual for your camera - https://manualsbrain.com/en/manuals/1042325/?page=109
    page 109 details on how to connect to a computer.
  8. Already have it pretty darn sure I have the dv settings correct from what the manual says but like I said still nothing. Seems a bit vague they only have about a half a page on the dv in function. Also Iím just trying to figure out if the camera is actually broken possibly.
  9. Make sure your camera is properly set for DV or HDV before plugging in. Avoid hot-plugging. Systems can also be finicky about whether the computer or camera are powered up first.
    Feb 2006
    does the camera have an internal button cell battery ??
    if yes, then you might try removing all the batteries and let the camera reset to
    factory default settings and then retry connecting to your computer.
  11. Ok cool thanks guys Iím really appreciating all the help, going to give it the old college try and Iíll report back ASAP
  12. Member Cornucopia's Avatar
    It's usually best to go:
    Connect devices while both turned off.
    Turn on computer. Login.
    Turn on peripheral.
    That way, it sees the initialization.
  13. Ok did everything here suggested except looking for the battery. I adjusted the settings per manual for hdv dv then turned off camera. Plugged camera in with computer off then turned computer on waited untill full start up and then turned camera on and still no connection
    Feb 2006
    does the mac have the option to search & add new hardware like windows does ??
  15. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    either the camera's firewire port is dead or the cable is. if the cable works with other cams and your computer, you then know what the issue is.
  16. Originally Posted by aedipuss View Post
    yeah cable works perfect with the sony cam no problems, I think the firewire port is dead. Thanks for everyones help on this.
