Hi all,
My first post...thanks for having me!
I have started working on an old movie from the 30s (source is a DVD). I would like to perform the following tasks, but are unsure of the order in which they should be done:
-- deinterlace
-- degrain
-- brightness/contrast
-- sharpen
-- 25>50 fps conversion (plan on using DAIN)
-- AI Upscaling (plan on using Topaz Video Enhance AI)
-- DeOldify (this part is just for fun...not saying I would keep it, but would like to know where in the order i should go)
Thoughts are welcomed! Thank you in advance
Joey
Results 1 to 17 of 17
You're in New York, yet you're working with a PAL source?
Movies, by definition, are progressive. Why would you deinterlace it? Maybe provide a 10-second sample from the source (either VOB or M2V), one with steady movement.
In my own restorations I denoise/degrain as one of the first steps and work with the brightness/contrast/levels later. In between I work on removing artifacts (scratches, splices, remaining dirt, damaged frames, etc.). Near the end I might sharpen.
Why? I slow PAL sources (if that's what you have) to film speed and leave it there. Do you intend to interpolate to 50fps (I have no idea what DAIN is)? And, if so, why?-- 25>50 fps conversion (plan on using DAIN)
I don't know what 'deoldify' is. -
Yes. This movie was only offered in the UK.
True, but DVD standard is interlaced...this VOB is no exception, and it was done quite poorly.
Good to know...thanks!
You should check out DAIN....Google some examples. I will be saving this project at each of its steps...I am not saying I'm keeping every step I try...just experimenting.
You should check that out as well. That is nothing more than a novelty for this project and I likely won't keep it, but I am really curious to see how it turns out!
Joey -
My $0.02...
Ivtc or deint should always be first.
Sharpen should always be last.
In between, it depends, but one of the schools of thought says you need to noise/artifact reduce prior to restore/enhancement, so that the R/E isn't operating as much on the noise
If you do any additional resize or temporal interpolation, it probably should be done near the end (but obvs before the sharpen).
Scott -
What is this irresistible sexual attraction that some users have for deinterlacing (usually the worst way) and upsamplimng (ditto)?
Apparently they have some really poor, cheap, disastrous playback systems that can't deinterlace or resize. You might have to deinterlace for cleanup filters, but QTGMC is the only way to do it. A decent player or TV can deinterlace and resize a hell of a lot better than you can with software. Save yourself the trouble, damage, and disappointment, especially with upsizing.- My sister Ann's brother -
Upscaling from MPEG DVD source? That won't look good.
There's zero reason to upscale SD, especially not when starting from compressed sources.
You'll just amplify noise.
Even if you do choose to stubbornly upscale, that Topaz software is craptastic. It's dummy-friendly, but that's it.
To concur: IVTC always first, sharpen always last.Want my help? Ask here! (not via PM!)
That is my version of "fun"....ie: tinkering.
That is the plan.
Doing this is none of what you suggest...it is a fun experiment.
You know...it is really comical. I am on another forum, of which I must say, I am an expert in the field. In this field I am a complete novice just trying to learn, have some fun, and experiment. So having forum experience, I love it when people ask a question, and rather than provide a direct answer to the question, they get a ton of reasons and opinons as to what they should or should not be doing with their time. I am glad I am seeing that pattern across many platforms instead of just the one I always participate on!
Thank you for confirming QTGMC
I asked this same question a number of years ago:
https://forum.videohelp.com/threads/347222-AviSynth-Order-of-Operations -
And you misunderstand what that means. You don't deinterlace films. Realign fields, unblend field-blended garbage, IVTC (but only for NTSC sources), but not deinterlace. At some point in your project you might want to use AviSynth. There are some things only it can do.
You're asking for suggestions and advice. You have to provide a short sample. Open a VOB in DGIndex. Scroll to a place with movement and use the [ and ] buttons to isolate that short section. Then File->Save Project and Demux Video. Upload the resulting M2V file. -
ESRGAN can work on B&W sources...
But the original research paper models were trained on color sources. Most pre-trained, publicly distributed models are also trained on color sources. Using a generic model that was trained on a variety of color sources, on a specific B&W old film source probably will not produce good results. Even if you used an appropriate model - the main problem with using ESRGAN on video is temporal inconsistency; you can introduce a type of flicker into the video. It's really meant for still images.
+1 to what manono is saying
If your content is progressive, such as a film source - I would take a closer look first. Most types of deinterlacing will generally soften a progressive source such as film. It depends on how the transfer was done, and the process used to put it on DVD. PAL DVD's are "interlaced" but the content can be progressive. If you deinterlace a clean film PAL DVD - even with QTGMC - you will just butcher it. You will destroy fine details. It's counter productive whether you're upscaling (or not). I know you don't have a "clean" or "good quality" DVD, but in general you want to avoid deinterlacing progressive content to conserve what little quality you have left -
I'm gonna edit what I said up above and mention in agreement:
It's almost always better to leave interlacing alone throughout the process. Or if you cannot leave alone, leave until the end.
Exception to this is always: film sources should be itvc'd when possible (ntsc), or rewoven deint when possible (pal). In a sense, you aren't really deint'ing a true field unique clip, you are just restoring the progressiveness. (Pal would prob also have a slowdown).
You CAN rework the fields so they maintain their interlacing throughout, without detriment to the fields during subsequent operations, by separating, working the odds & evens separately, and the recombining (naturally prior to any deint you want to do for the final web product, such as qtgmc-the most recommended).
My original thought was that since you said movies from 30s and you said dvd, it would fall under that exception. But I didn't mention it at the time.
ScottLast edited by Cornucopia; 29th Apr 2020 at 22:41.
Topaz will not upscale well with interlaced footage but works fantastic with progressive files. I highly recommend trying Topaz first to see the results you can achieve before doing anything else with the file. It cleans and sharpens as it enhances. Experiment with all setting. Ignore the recommended usage advice. My best results have been using the setting for computer generated video(CG) but it works great on poor quality SD files, even HD files actually.
-- deinterlace
-- degrain
-- DeOldify (I am not sure what you mean by deoldify or how you plan to do it so I'm guessing this one)
-- sharpen
-- AI Upscaling
Software to convert editing operations to the command line ffmpeg
By ctimict in forum EditingReplies: 2Last Post: 20th Feb 2019, 15:02 -
When does video restoration go too far...
By lingyi in forum Newbie / General discussionsReplies: 11Last Post: 22nd May 2018, 01:00 -
Process aborts during DVD Authoring operations
By Ladywolf in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2017, 15:12 -
ffmpeg order of operations - scaling footage and interlacing
By nesburf in forum Video ConversionReplies: 12Last Post: 31st Jan 2017, 18:40 -
Videos Restoration
By sinobn in forum RestorationReplies: 1Last Post: 14th Aug 2016, 12:11
