Results 1 to 10 of 10
  1. Hi, I want to convert a Flac audio track from a video to TrueHD. When I do this with Xmedia recode, it encodes it in "standard" DTS. Is there another way?
  2. Are you sure Xmedia recoder can convert to TrueHD?
    I thought the only tools capable of encoding TrueHD were those of Dolby itself.
    So my guess is that you will have to invest quite a bit of money to get a TrueHD encoder,...
  3. ffmpeg has an (experimental) TrueHD encoder. (Getting AC3+TrueHD is a different problem, though.)
  4. Well I managed to make this conversion with Xmedia Recode, it was just in the format selection. So now I'm asking if is this real TrueHD?
  5. DECEASED
    Jun 2009
    Heaven
    Use MediaInfo, or read what a professional BD authoring software says about it.
    Also, keep in mind that ffmpeg's MLP/TrueHD encoder compresses so poorly that the result has almost the same size as uncompressed PCM.
    "Programmers are human-shaped machines that transform alcohol into bugs."
  6. @ElHeggunte: Is it really ffmpegs TrueHD encoder or is it TrueHD in general?
  7. I cannot confirm this either way after a few tests. For one random Hollywood movie with 5.1 ffmpeg TrueHD encoder achieved 68% bitrate saving (without AC3 core). It's content-dependent, though, with the lowest saving being closer to 25%.
  8. DECEASED
    Jun 2009
    Heaven
    I have just compared an ancient version of ffmpeg (4.1.4) with a fresh one (git-2020-04-26-1128aa8). In general this latter compresses somewhat-better than the old one, but it still doesn't have the same efficiency of the official encoders from Meridian/Dolby.
  9. Thanks, good to know. btw. is there a freeware tool which can combine an ac3 and truehd stream into a ac3&truehd combi stream?
    ffmpeg, tsMuxeR, eac3to (and probably mkvtoolnix) can be used to split the combi stream, but how to recombine it?
    Cu Selur
  10. Haven't seen any, but eac3to can encode a (new) AC3 core to an existing core-less TrueHD file.
