Results 1 to 10 of 10
  1. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    G'day
    I have this extremely large mouse pointer that I cannot get rid off. I was trying some larger pointers and after I tested this one I could not go back to a normal pointer. What can I do that I haven't done yet. I tried installing small ones from the net but they come big after installing.
    I don't want to reinstall Windows again and restore points don't work in W10.
    Thanks for any help.
    John
  2. Member DB83's Avatar
    Jul 2007
    I do not know about Win10 but in Win7 the size of the pointer is controlled by Control Panel >> Mouse >> Pointers >> Select a Scheme
  3. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    I know that Bro. It doesn't work.
    Thanks for answering.
  4. Member DB83's Avatar
    Jul 2007
    The pointer could be running independent of Windows (in it's own app). Locate the app and check it's settings. There may be one to restore to Windows pointers or words to that effect.
  5. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    What I did was I clicked that on the picture attached
  6. Member DB83's Avatar
    Jul 2007
    That exists in Win7 as well. But it is independent of the Mouse Pointer setting I described above.
    Oct 2005
    666th portal
    did you try re-booting?
  8. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Every day, more than once a day, I never keep the PC, nor the modem on if I'm not using it.
    Sep 2016
    Could try to rename the registry key HKEY_CURRENT_USER\Control Panel\Cursors and reboot.
  10. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Solved.
    I reinstalled Windows 10. Kept my apps and my files. Took me the afternoon, but. All is working, Windows and Office are activated and I'm pleased with it.
    Thanks for your posts.
    John
