Hi,
New to the forum.
Just bought a G7 for videoing for youtube and need a 4K capture card for it. Should I go for the camlink as they are pretty expensive. Is there a cheaper alternative that will do the job as well?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
If you are asking about the Elgato Cam Link 4K, in the USA it is priced at about $130, which seems quite reasonable for a 4K (2160p30) capture device. Some others, such as the Magewell USB Capture HDMI 4K Plus, have a much higher price.
Of course, the Magewell USB Capture HDMI 4K Plus offers additional features, including the ability to capture 2160p60 input, which may be well worth the ~$460 price for some buyers who need those features.Last edited by usually_quiet; 29th Apr 2020 at 12:43. Reason: grammar
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I'm from the UK.
This is the one I was thinking of getting. Guess if that's a good price then fair enough!
https://www.argos.co.uk/product/7350588
Thanks for the reply -
Lumix G7 ? why not Atem mini (pro) or any other streamer ? a capture card is not for live events, but more for recording.
yes, go for the elgato camlink, reasonable price any cheaper option will be crapeasyLast edited by Eric-jan; 29th Apr 2020 at 15:15.
Using Canon's EOS Utility to capture on screen video VS a capture card
By RoyZ7 in forum CapturingReplies: 0Last Post: 23rd Apr 2020, 07:18 -
Adding a new External Capture Card to my Hauppauge Colossus Internal Card
By MounaLafi in forum CapturingReplies: 30Last Post: 21st Feb 2019, 14:40 -
best capture card for vhs and hi8 capture
By hdfills in forum CapturingReplies: 4Last Post: 18th Oct 2018, 11:21 -
Can't capture signal from JVC HR-S9911U VHS deck into Hauppage capture card
By vhscapture in forum CapturingReplies: 3Last Post: 18th Jul 2016, 12:07 -
Is the Canopus ADVC-50 card still an OK capture card?
By Mickey Juice in forum CapturingReplies: 8Last Post: 21st Feb 2016, 08:34
